Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Just replaced the lamp. no picture yellow light flashing?
    President:
  • Mitsubishi Master
  • 1,619 Answers
There may be a capacitor issue with that unit. Here is a link to a thread on help to repair that if it is an issue.
http://www.techlore.com/forum/thread/20256/Mitsubishi-WD-52525-has-a-continuious-blinking-light/
Posted on Apr 26, 2010
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
May 06, 2010 | Hitachi EDX-3280 LCD Projector
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
The lamp yellow light keeps flashing so nothing works
you need to make sure the door is all the way tight. there is a switch there and if it is not making contact you will get a yellow status light
Feb 22, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
204 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
