Question about Northstar 951XW GPS Receiver
Waypoints and nav log
My Northstar 951 will not save waypoints, it resets when the boat is turned off or I restart the motors
  • 3 Answers
Based on your description I would suspect that the internal memory battery is depleted and needs to be replaced. This battery is required to retain waypoint and route information when the input power is low or turned off. The battery is soldered onto the main circuit board and needs to be replaced by a technician having good soldering skills and access to instructions for the disassembly and reassembly of the unit. There is a list of dealers on the Northstar website. Review the list and make a couple of phone calls to see which ones will do bench work on this unit.
Posted on Jul 13, 2008
I have a chip with with waypoints. How do I download it into my unit?
Use a USB cable that will connect where the power cord plugs in. Have a fully charged battery before you try.
Aug 08, 2015 | GPS
Trackfish 6600 stops and starts again by himself many times in a few minutes; first screen map thouthand miles away from real boat position !
Try a factory reset - that worked for me when my Northstar Explorer 660 stopped by itself again and again. You find this reset commando by pressing MENU twice and then under Systems menu, if I remember it correctly. There is also a RAM Clear commando. This is done by holding the MENU button pressed when the GPS is switched off. Keep it pressed while switchin on the GPS, still holding the button pressed until the RAM Clear menu appears. You will probably loose all waypoints etc. by doing this so try Factory Reset as your first alternative. Good Luck! // Jonas, Sweden
May 12, 2011 | Northstar Explorer 660...
Black screen
If it is connected to the boat motor check the voltage that is coming from the engine and clean the battery post. This solved the screen flickering.
If you don't want to do that just call Northstar customer support and see what they suggest.
Phone (Toll-free) 1-800-628-4487 or (Direct) 603-324-2042
That will get you better support.
Jun 09, 2010 | Northstar Explorer 657...
Need a northstar 951 X power cable
I may have one, as my screen is dead, like MANY others!
Oct 24, 2009 | Northstar 951XD GPS Receiver
Northstar 600i locks up and at times you can't switch screens, turn it off or even turn it on. You have to wait and come back later to turn it off or on???
If you can delate all you log, waypoint routs or make a masterreset.
With a masterreset you will lose all data below
Sep 23, 2009 | Northstar 6000I GPS Receiver
We keep loosing contact to the sattelites. Is there a way to reset it, so we get a constant signal?
Mine did the same, and said no gps no fix. I called the factory, now called Northstar, tech said to reset unit, and it worked. Great signal strength. Turn unit on and access menu, access factory settings,hit factory reset. However you will lose all your waypoints.
Jul 04, 2009 | Navman Tracker 5500i GPS Receiver
Northstar 951 GPS shows boat moving & @ high speeds (over 100)
RE: Northstar 951 GPS Receiver
Contact & Support @ http://www.northstarnav.com/en/Support/
jack
0501102.jpgPlease Rate This Now or Later!
Feb 22, 2009 | Northstar 951XD GPS Receiver
Looking for a mounting brackett and thumb tighteners for a 951 x
thank you for your effort. I resolved my problem at a local marine shop.
Feb 16, 2009 | Northstar 951XD GPS Receiver
Furuno 1833C/Dgps37 Plotter creeps
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Jan 11, 2009 | Furuno 1833C/NT GPS Receiver
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
Northstar 951XW GPS Receiver Logo
121 people viewed this question
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
