Question about GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
Freezer compartment not working
No sound of compressor
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer compartment not working - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
Freezer is making a loud noise, assume when compressor is on. Pretty much as soon as the door is opened, the noise begins. Things are still frozen inside.
inside the compressor body there are springs which sometimes break and allow the
motor to knock against the outer enclosure. There is no fix for this as the system is
sealed, short of replacing the compressor. Not a problem with operation, but quite
distracting.
On another note, if the freezer compartment is beginning to freeze up or the fan
blade was installed too far back on the shaft, this could also cause noise.
(it will only make the sound in the freezer compartment when the fan is running
if this is the case). Hope this helps.
Apr 28, 2011 | Woods Freezers
Freezer not working
I'm uncertain as to exactly what you mean by "the freezer is trying to come on"? However, there may be an issue with the compressor or the components that attach or work in conjunction with the compressor (e.g.: relay, start capacitor (if applicable) and overload). Pull the refrigerator out and simply listen for an intermittent "buzzing or clicking sound) coming from the lower rear compartment. If there is such a sound, then you may very well have an issue with the aforementioned parts or the compressor itself. I recommend an appliance service company!
Feb 10, 2010 | Maytag MSD2655HE Side by Side Refrigerator
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
Jun 02, 2009 | Refrigerators
Freezer and fridge running too warm
sounds like you might have a bad compressor or the start components for the compressor is bad.
Apr 25, 2009 | Refrigerators
Refrigerator/freezer has stopped cooling
Sounds like you need a new relay for the compressor. Unplug from wall and check the compressor see if realy that is attached to pins on compressor, is burnt.
Apr 05, 2009 | Kenmore 53082 / 53084 Side by Side...
LOAD CLICKING SOUND WHEN PLUGED IN TO ELECTRIC
did you just get the freezer or move it recently? this unit doesnt have any fans so I'm thinking the compressor is somehow out of place and when you plug it in the compressor is hitting its steel shell from the inside. remove the compartment cover on the side then plug the freezer in and see if the compressor is making the noise..
Jan 22, 2009 | Freezers
Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Oct 13, 2007 | Refrigerators
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
82 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
