Question about Kenmore Elite HE5t Washer
Kenmore He5t washer: Code F27. What do I need to
Kenmore He5t washer: Code F27. What do I need to do?
  • 15,935 Answers
F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following:
1. First, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2.
2. Check the drain hose and make sure it is not plugged or kinked.
3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
4. Check/Clean Drain Pump Filter of foreign objects.
5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off
7. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pulling a vacuum on it with a shop vac. You may have an obstruction in the drain line or drain pump. It is also a good idea to check the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub and runs to the inlet side of the drain pump. This area can get clogged with small articles of clothing.
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the clear tubing (air hose) is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. This may generate an F27 error.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. Look for obstructions in the clean-out trap and impeller area of the pump.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off. You need to ask yourself if you find standing water in the tub when not in use.
5. The "Sud" error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent, HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause an over suds condition.
NOTE: Knowingly or unknowingly using the improper detergent on these model washers MAY void your manufacturer's warranty. Read all instructions and documentation that comes with the appliance, thoroughly.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a component failure (more commonly, the CCU or pressure switch)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
I have a Kenmore He5t steam washer. I got the F35 code again, so I automatically ordered and replace the pressure switch again. did not fix the problem. I have checked and cleaned the drain basket and
Unfortunately you spent money unnecessarily, and before making any additional errors; it would be best to have a trained technician with knowledge of the washer, service the system.
Jan 18, 2015 | Kenmore Washing Machines
What is F27 error code?
The F27 error code indicates an overflow condition. If the washer is overfilled and continues to fill with water, this would indicate that you have an inlet water fill valve that is stuck open. If you unplug the washer and water continues to fill the tub, then the inlet fill valve assembly will need to be replaced. Make sure that the drain system is properly installed according to the installation instructions. An improperly installed drain system could result if siphoning of drain water back into the washer.
Check to see if the drain pump is working properly to pump out the water. When the F27 occurs, the drain pump will run constantly to pump out the water. The door will remain locked. Shut off the water supply faucets behind the washer. If water is not being pumped out of the washer, you could have a clog in the drain pump or drain hose. The following link of a previous answer provides advanced troubleshooting for a drain problem:
Why won't my HE4t washer drain?
If the washer is not overfilling and the F27 remains even after the washer is drained, then it is likely that you have a failed pressure switch. A failed electronic control board in the washer could also cause this problem. To access the pressure switch, unplug the washer and remove the top panel. Screws at the very back of the top panel secure it to the washer. Remove these screws and pull the top panel slightly back and then up and off of the washer. Sometimes, you can reset a stuck contact in a pressure switch by tapping on it with the handle of a screwdriver. I you cannot reset it, the pressure switch will need to be replaced. If you have the same problem after replacing the pressure switch, you will likely need to replace the control board in the washer.
Aug 19, 2014 | Kenmore Washing Machines
Kenmore he5t washer Changed the pressure switch.
F21 means long drain. Yes, there is something be in the hose. You need to open the filter and clean the pump, too.
Oct 19, 2013 | Kenmore Elite HE5t Washer
I have a he5t washer that gives code sud then code f 21is there a filter that can get cleaned or is it the drain pump
Very common issue, you need to clean the drain pump. You can watch a video that shows how to do so at the link below, let me know,
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Kenmore Elite HE5t Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
F20 message on washer kenmore elite HE5t
http://www.fixya.com/support/r3608632-f20_error_code
Feb 28, 2010 | Kenmore Elite HE5t Washer
Kenmore elite he5t washer wont start or light up
Take the top cover off with the 3 torque screws. need to check if there is power going to the interface board. If there is then the interface board needs to be replaced
Nov 04, 2009 | Kenmore Elite HE5t Washer
I am repeatedly getting an F20 error on my Kenmore HE5t washer. It seams the the spin cylce before the final rinse is the sticking point. I have to unplug, restart and finish the cycle with final rinsie...
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
Oct 12, 2009 | Kenmore Elite HE5t Washer
My kenmore he5t washer will not turn on. The on
I have the same problem . If I power cycle mine enough times I eventually get a F70 or F71 code. My research online suggests that the user interface board has a problem and needs to be replaced.
The good news is the warranty covers these boards for two years. The bad news is they are $360 if you are out of warranty.
HTH
Jun 12, 2009 | Kenmore HE5
Kenmore Elite HE5t Washer Logo
1,234 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
