Question about Rowenta Irons
Looking for Microtemp 4358A fuse for Rowenta DA-55 steamer. Is the part available? Where is it available and what is the price? (Sorry, but you don't list an expert in steamers.) Thanks.
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
SOURCE: My Rowenta Garment Steamer will not steam up.
I had the same problem and noticed that there is a small plastic piece that pushes into the water reservoir to release water into the boiler. Mine broke off, and no water leaves the reservoir into the boiler. It looks like suspect design to me, and I havent found a replacement part but I may try to epoxy the piece back on to solve the issue (I hope)
Posted on Apr 23, 2009
  • 26 Answers
SOURCE: Is there a product to run through a rowenta pro
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
Posted on May 19, 2009
SOURCE: on and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Posted on Jun 13, 2009
SOURCE: I have a Rowenta Garmet Steamer (Commercial) and
I have an 580 or is it 9850 stemagenerator, and having trouble with getting the steam, what should I do.
Posted on Jan 30, 2010
Where don I put in the water on my DA-55 steamer
http://www.rowenta.co.uk/rowenta/frame.aspx
Feb 11, 2015 | Irons
Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Nov 07, 2013 | Rowenta Irons
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
How do i open d rowenta garment steamer to change the fuse or burnt wires
There are four screws (Phillips) but you need long thin screw driver to remove them. Then there are TWO screws underneath the Castors. Just pop the Castors and turn them and you will see the screws. BTW there are two fuses inside. One you can replace and the other one is soldered in and you need to be little skilled to replace it. Chances are if the first one blew the second one should be OK. Good luck.
Jul 04, 2011 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
Irons Logo
773 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
