Question about Texas Instruments TI-89 Calculator
Error name is not a function or program - Texas Instruments TI-89 Calculator
  • kakima May 11, 2010
    You're treating something that's neither a function nor a program as if it were. You've got a statement or a command that uses a name followed by parenthesis when the name is not a function nor a program.
    For example, foo(x) when there is no function nor program named foo.
    When the error pops up again, press ENTER and the calculator should take you to the point of the error. If you post that line, perhaps someone can identify the problem.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on May 28, 2010
Por error bloquie la pantalla de mi tv es un sharp slim como lo puedo desbloquear?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. .
Nov 26, 2016 | Sharp Televison & Video
How to program a np name remote wiyhoiy a setup bitton
Programming Notes
Oct 03, 2016 | Televison & Video
The program Manuel codes lm1075 4 function universal remote to a hisense tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
Sep 27, 2016 | Hisense Televison & Video
Rca DTA880 programing my universal remote to it
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
Jul 13, 2016 | RCA Televison & Video
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
Im trying to create a program to run the colebrook formula but after i program it and enter the unknown i get error data type and brought back to program editor screen.
The error data type means that the program is expecting a specific type of data ( number, list, matrix, real, complex, string, etc.) while you are feeding it some other type of data. The point in the program where you are taken when the error occurs is where the exception was launched.
A common source of error stems from the use of variables that are global and defined in some other program. You can use the same name inside your program as long as you declare the variable local.
If your program is in fact a function, then all its argument must be passed in the call to the function: You cannot ask a function to read your input.
I will not pretend to know why you get the error, but the few comments I made above may help you debug the program.
By the way, if you are interested a Cobebrook online calculator, here is a link
Apr 26, 2011 | Texas Instruments TI-89 Calculator
I tried using store function but a pop-up states: "Variable or flash application is locked, protected, or archived." what do i need to do to fix it?
You may be trying to store the function in a folder that already contains that function or name. Its called Error Folder, and you will get the errors you mentioned. Try copying the function under the same name to another folder. Go to the other folder, the one you just copied your function too and, rename the function something you don't think will conflict with the original folder. Simply store your function with the new name in the original folder. That should work, and hopefully you won't get any errors.
Dec 21, 2010 | Texas Instruments TI-89 Calculator
I am attempting to program the atomic masses of the elements into my Ti-86 using the Store feature and Capital and lowercase letters, (ie. 54.938>Mn) and I got all the way to Lu, when it gave me an...
There is a built-in function called LU (for LU-decomposition of a matrix). You cannot have a variable with the same name as a function, regardless of case. You'll have to find a different name to use.
Nov 22, 2010 | Texas Instruments TI-86 Calculator
VB6 error 432 File or Class name not found during automation
The GetObject function requires either a valid file name with a path specification, or the name of a class that is registered with the system. This error has the following cause and solution:
The name specified for file name or class in a call to the GetObject function could not be found.
Check the names and try again. Make sure the name used for the class parameter matches that registered with the system.
Mar 08, 2010 | Computers & Internet
I am trying to install QuickBooks Pro 2007 on a new computer that has Windows Vista Business with SP1, and I had updated Windows, then installed QB but when I imported the company file, QB gave me a...
Why is this happening This issue can occur as a result of uninstalling the Google Desktop installed by Quickbooks on a computer running Microsoft Windows Vista. Launching QuickBooks after uninstalling Google will cause the error message.
Note: This issue is also known to occur with computers that have been upgraded from Windows XP to Windows Vista, where Google Desktop was uninstalled under Windows XP. Both cases would yield the same error message.
How to fix the problem This issue was resolved in the latest release for your version of QuickBooks.
Detailed Instructions Please update your program to the most current release.
just click on that link above then click on the 909ffb0.jpg(update) image on that page.
Oct 27, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Texas Instruments TI-89 Calculator Logo
2,970 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
