Question about Gateway 450SX4 Notebook
Fan running alot and laptop gets pretty hot - Gateway 450SX4 Notebook
  • 183 Answers
Try using a can of compressed air to blow out any dust build up. also unscrew the panel(s) on the bottom and dust those out too but don't physically touch the parts inside. Also do not tip the can of compressed air upside down or anywhere close to a 60 degree angle which would cause foam to come out of the can.
Posted on Apr 26, 2010
Fan always running
there might be alot of dirt and dust around the fan blocking it from cooling the laptop down,or it could be the processor over heating,get it check for heat paste on the processor.
Jun 24, 2014 | Sony VAIO VPCEC3DFX/BJ Laptop Computer -...
Fan runs alot and the laptop over heats and shuts down
hello
keep your notebook well ventilated (there are vent grills at bottom that ned to be kept ditanced from the notebook to the flat hard surface where you place the notebook. Also, try to clean the fan , by removing bottom cover : use air can to blow away dust - clean the fan. If the system has never been cleaned before, i can assure you there is mounds of duct inside , especially on the fins of the heatsink fan that cools your CPU and video card. I would also suggest getting air compressor to blow away the dust , if there is too much of it inside. YOU MAY HAVE TO REPLACE THE FAN unit . You can otherwise , go to teh BIOS set up nad reduce the fan speed.
Feb 25, 2012 | Toshiba L505D-S5965 (PSLM0U-00F002) PC...
It seems that it get's oveheating when you watch a movie or a game and the fans are alwayas running. Anythiing except navigating on the net cause the fans to run and they get pretty hot.
The over heating depends on the usage and type of applications running in the Computer. You can clean the Air vents of the Computer to avoid the Over heating. Also, change the Power schemes of the Computer from Control Panel in Power Options
Jul 09, 2010 | Acer Aspire 5100 Notebook
My notebook fan wont come on
Usually the fans only come on when they are extremely hot. The fan will not run alot or it'd kill the battery really fast. You could always get one of those notebook coolers that sits under and connects via usb.
Sep 12, 2009 | Toshiba Satelite A135-S4487 Notebook
1995 buick lesabre fan relay
alot of us back yard mechanics just wire it straight to the fuse box . on a fuse that is only hot when car ignition is on saving you alot of headaces
Aug 16, 2009 | 1995 Buick LeSabre
Over heats somtimes won't turn comuter very hot
Try to buy a external cooling system to prevent the over heat of your laptop. here's the link below to some external cooling system design for laptop.
Laptop External Cooling Pad Design
Thanks
Jul 31, 2009 | HP Pavilion dv6119us Notebook
Sunfire overheating, not low on coolant
Sensor on the engine sends info to the computer that triggers fan relay and sends power to fan. Most often problem is sensor or relay but quick check fan itself by hot wiring it to the battery Polarity is not an issue...if you get wrong it will run backwards. If it does not run, it's bad.
Jul 30, 2009 | 2001 Pontiac Sunfire
Dell 1501 machine cuts out on fullscreen video
I work on alot of Dell's and computers in general and it's been my experience that when a laptop heats up to the point of not being able to touch it, then the CPU fan has failed. Dell has been pretty good about replacement defective parts, expecially in warranty but they've replaced alot of my customers parts out of warranty.
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Need to replace toshiba satellite m35x-s163 fan
Unless you are really comfortable with opening laptops to upgrade parts, I won't recommend doing this. Rather get a notebook cooler. It does the job of cooling the notebook pretty well.
Nov 05, 2008 | Toshiba Satellite M35X-S349 Notebook
Gateway laptop
This could be a problem with your fan, whcih could be going out. it could also be the battery. check to make sure your battery is not listed on gateway's site for recall. last year a ton of laptop batteries were recalled for overheating and casusing meltdowns in latops. My own Gateway latop was one of them and got replaced for free because of it.
Also, I've found gateway laptops run a bit hot anyway, so I would buy a cooling pad with a fan or two inside to take the edg off the heat. it will increase the lifespan of your computer and mostare very quiet as well. Make sure you get one that is powered by USB so you don't have an extra power cord to worry about.
Jul 09, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
