Question about Whirlpool Duet GHW9150P Front Load Washer
Just bought a used duet washer...what does control lock mean...and how do we fix it?
  • 5,911 Answers
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on Apr 26, 2010
THE DISPLAY WINDOW SAYS CONTROL LOCK. WHAT DOES THIS MEAN?
Press and hold the End of cycle button for 3 seconds or until the Control Locked indicator turns off. Click on the link below for more details if pressing and holding the said button doesn't unlock the controls.
Unlocking the Controls on Whirlpool Duet Washers
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I cannot use the washer. The "Control Locked"
Hello
Control locked means that the control is locked and needs a Reset, try pressing the END OF CYCLE button and hold it for 15 seconds to solve the problem. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock is lit up and will not go to any
This happens often, pressing buttons, sometimes it can be easy to slide into control lock. I have this link that shows how to turn it off.
http://www.managemylife.com/mmh/questions/193855-how-do-i-disable-the-control-lock-on-my-duet-washer
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get our whirlpool duet washer control lock light off ?
Hold the end of signal volume button down for 3 seconds to turn the control lock on and off.
If that does not work then: a) unplug the washer or b) put the washer into diagnostic mode using the instructions from this thread http://applianceguru.com/forum2/1540.html.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control is locked
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
