Question about GE Profile Harmony DPGT750GC Gas Dryer
No heat We have cleaned the vent, checked the breakers and it doesn't seem to get hot. What could be the problem
  • GE Master
  • 43,501 Answers
If you have a gas dryerNo heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 26, 2010
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
_don@hotmail.comthe heat control function doesn't seem to be working, the clothes get very hot regardless of setting. which device controls the temperature? Thanks for your help. Don
Hi ngentry don...
Your overheating problem is not caused by the thermostats...
Do the following:
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Sep 05, 2011 | Dryers
My dryer runs and heats up but doesn't dry the clothes. i noticed some dampness on dryer door when i open it. the clothes circulate but don't fully dry. i noticed the dryer is heated and light is...
Hi mandolins23...
Sounds like your venting system is plugging up, try these suggestions below...
Aug 30, 2011 | Kenmore 600 7962 Dryer
My fridgidaire dryer model FDR336RDS2 seems to run too hot
Over heating in a dryer is almost always due to an air flow problem. Typically it is in the venting.
- Check the vent from the dryer to the wall by removing it and cleaning out, make sure there are no kinks or tears in it.
- Run the dryer once it is connected and feel outside to see if you are getting the same airflow outside as you can at the outlet of the dryer, if the air flow feels weaker outside your vent is restricted and you need to have it cleaned.
- If these are ok check your lint filter, softener residue can plug up the screen so air has trouble flowing trough it, you can wash it out with a brush and hot water
- With the lint screen out take a flashlight and look down the chute, if you see lint in there take a brush and vacuum and clean good
Apr 22, 2010 | Frigidaire GLER341A Electric Dryer
Dryer gets really hot, blows circuit breaker, vent is clean and clear, circuit breaker replaced, seems to be something that controls the heat isnt working..
Howdy: In back of the dryer is a thermostat (inside) that lint hangs to. If it reads too hot it should stop heating. If not working then blows breaker. Inspect please, we do not want a electric fire. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer takes too long to dry clothers and yes I cleaned all the vents and there is no clog or stoppage in vents
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 06, 2009 | Estate TEDS740JQ Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
Jan 10, 2008 | Dryers
GE Profile Harmony DPGT750GC Gas Dryer Logo
173 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
