Question about Smith SOLDERING BRAZING GAS SAVER CUTTING TORCH WDW101
Torch was emitting a bit of black smoke. I could see blue flame through little holes at base of torch tip. Afraid to turn it back on.
4 Suggested Answers
  • 4088 Answers
SOURCE: torch is used for jewelry work and is a acetylene
Usually, the blow-out problem is caused by excessive fuel flow at first--too much pressure or valve is opened too far. Once you have a bushy acetylene flame, turn up the air source to bring the flame down to a fuzzy point near the tip end. Brazing and silver soldering work better with just a little less air. My experience is with an oxy-acetylene torch, but results are similar.
Posted on Jul 23, 2009
SOURCE: How do I service Oxy-Acetylene gas welding mixer
sounds like your needle valves are worn or damaged,also change allthe q rings in same valves
Posted on Jan 06, 2011
luis_david
  • 407 Answers
SOURCE: Hi there, despite brand new
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Posted on Oct 06, 2011
Pencil Torch flame is not powerful welding torch, its a lighter flames and flames come out the sides through the air holes. How can i fix this? Thank you
Try turning the valve down or towards the off position. It may take some fine adjusting to get it just right.
May 02, 2016 | Welding Tools
My question is in bbq grills w/pic.The flame on this torch is now like a lighter flame, i want a torch w/ power and the flame is coming out the air holes. Can this be fixed?
check burner is not blocked check all holes in burner are not blocked . make sure burner is not split , what you have is light back to the injector .
May 02, 2016 | Grilling
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
WE HAVE A BERNZOMATIC ST200 MICRO TORCH AND MY HUSBAND IS TRYING TO SAUDER HIS GUITAR HE CAN'T SEEM TO GET IT HOT ENOUGH TO MELT THE SAUDER. THIS IS ONE THAT IS A TORCH SAUDER COMBO THING. IS THERE A...
with the solder tip attached push upward on the little black knob on the tip, its spring loaded and on one side reveals a small little chamber where you can see a small flame once you turn the gas on and apply a spark/match to the little opening. keep the knob still pushed up all this time. let the fire inside keep going, if you let the knob down and the window to the chamber closes before it gets hot enough the iron wont work but if you wait for a bit with the fire inside, then right below the tip you'll start to see that area glow red, once its glowing red your good to go, you can close the chamber and the catalyst will "burn" the gas in the area and make heat instead of the fire heating the tip. once you close the chamber you're holding open with your thunmb then the fire goes out, if its hot enough you're set to go, otherwise rinse repeat.
Oct 30, 2010 | Garden
I'm unable to get blue flame on orca torch, it makes a crackling noise when I light it and has yellowish gunk in the tip, Can you help?
Is this torch powered by acetylen and if so then the yellow gunk you are seeing is unstable acetyleen which is caused by a torch that is releasing the gas faster then it can be handled in normal atmospher whic would be why you can not get a blue flame, I would say that the tip is to large for the tanks you have the system attached to. I would ask your dealer to suggest the tip size that the torch set you are using would be compatiable with the tank size you have attached. I would not try to use the set until I get it sorted out as unstable acetyleen is very explosive. Hope This Helps Don
Dec 17, 2009 | Computers & Internet
Torch is used for jewelry work and is a acetylene air torch. the torch keeps going out when lite. also would like to know how to adjust the air flow on the tips and what it should be. thanks
Jul 23, 2009 | Welding Tools
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
Smith SOLDERING BRAZING GAS SAVER CUTTING TORCH WDW101 Logo
53 people viewed this question
Top Smith Welding Tools Experts
Bill Boyd
Are you a Smith Welding Tool Expert? Answer questions, earn points and help others
