Question about Samsung CLP 315 Laser Printer
Paper feeds but stops right before it spits it out all the way - device is about 2 years old.
    Sergeant:
  • Samsung Expert
  • 406 Answers
THIS IS A PROBLEM WITH EXIT SENSOR. IT CAN BE CHANGED BY SERVICE ENGINEER
Posted on Apr 26, 2010
We are having paper feed problems with this two year old printer, including paper jams, black roller marks on the paper, etc. Help!
1. clean the feed rollers
2. check if the feed rollers work
3 check if have a piece of destroyed papper in the road of the paper
4 clean the sensors (all cleans with ajax)
5 the feed rollers you can clean with the WD40
Nov 19, 2010 | Dell 5110cn Laser Printer
Paper feed error message. spits it out fast and
Your printer has a fail safe mechanism that pushs the paper that it's processing out to prevent any other jams during the printing process. Your rollers must have something jamming it's movement during printing. You will need to open the printer through the panels on the back, front, and side to ensure that you see the rollers and remove any paper or debrise blocking hitched on the rollers or in the printer. You may also want to ensure that the holders on the sides of the paper tray where the paper comes in are lined up correctly. Also, make sure not to pack the paper tray to capacity. Only use the tray half full.
Nov 29, 2009 | HP Designjet 70 InkJet Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Paper feed issue
You didn't setup the paper size correct, check again in the driver and application to have the same dimension with the actual paper in printer.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jun 04, 2009 | Konica Minolta magicolor 2400 Laser...
My Mita 1860 give a miss feed reading an stops half way
Is the paper tray size set to the proper size -if you have the paper mismatched the machine could act this way:
for example "letter size (81/2 X 11) paper in the tray and the tray set to "Legal size" (81/2 X 14)
Mar 26, 2009 | Office Equipment & Supplies
Paper jamming
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | HP Photosmart 2575 All-In-One InkJet...
Paper feed problem
Good luck...
Sep 11, 2008 | HP DeskJet 6540 InkJet Printer
450 c
Make sure your paper is aligned with the left edge of the rectanglular holes on the right side of the printer paper feed slot
those slots are monitored to check for proper paper alignement and if it is not --it spits out the paper
Jul 25, 2008 | HP DesignJet 450c InkJet Printer
Kodak printer
ohh..sounds like the drivers are blown...go to www.kodak.com and get new ones.
Jun 03, 2008 | Kodak Office Equipment & Supplies
Paper Feed Problem
I had same problem... eventually just started using 8.5 X 11 paper to print photos with smaller sizes.
Mar 30, 2008 | Epson Stylus Photo R320 InkJet Printer
Samsung CLP 315 Laser Printer Logo
126 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
