Question about LG 32LC7D Television
Loud hissing noise when t.v. is on. It bagan with occasional vibrating with the screen picture. That stopped but the hissing continues.
Hi I have a geberit cistern 222.013.00.1 with hissing noises and tank keeps topping up occasionally
wait for the new washer/ valve to settle in
or turn down the inlet water tap a bit
what does this really mean
tank topping up with water and re filling occasionally
in the wrong way or too tight or the wrong part ?
Nov 09, 2016 | Home
Dryer occasionally makes a loud vibrating sound
Under warranty - contact retailer or manufacturer - check user manual or receipt for procedure.
May 30, 2016 | Blomberg DV17540 NBL00 Vented Dryer with...
I have a 2005 Pontiac that makes a hissing noise underneath the car. you can turn the car ignition on without fully starting car and it still makes hissing noise then stops.HELP!!!!!
There is a distinct sound that has a hissing component when you first turn on the key. It will last a second or two when the key is turned to the run position. When the engine started the sound will return and continue to produce the noise so long as the engine is running.
A relatively low noise is normal. If you are concerned check other like cars for the loudness level.
how to check your fuel pump
The pressure regulator on the fuel rail can also produce a sound when the fuel pump is running. The regulator is under the hood and any reasonable noise would not be a concern, A clicking sound is also normal throughout the fuel system when the engine is running created by the fuel injectors cycling.
Dec 28, 2015 | Pontiac Cars & Trucks
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
ALARM KIND OF NOISE THAT WILL NOT STOP WHILE DRIVING. IN AUDI 2006
does it come from inside the cabin might be a fault with the seats or seat belts as when you get in and dont put your seat belt on it makes a beeping noise untill the seat belt gets put on is it this noise could be a faulty seat sensor wouldent of thought it was the turbo hissing or screeming yes but not a buzzing noise but then i could be wrong hope this helps ivan
Oct 24, 2012 | 2006 Audi A4 2.0
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Optoma ep716 loud noise
the colorwheel needs replacing. the bearings are shot.
Jul 25, 2009 | Office Equipment & Supplies
Optoma ep716 continuous loud vibration noise when turned on.
the fan motor could be failing. turn it on with the top off. if one of the fans is moving slower, that'd be the one. since this is a dlp projector, the colorwheel motor berings might be on their way out as well. both need replacement.
Jul 25, 2009 | Optoma EP706 Projector Remote Control
TV turned off and wont come back
looks like the color wheel its bad in the set,color wheel its not spining at its proper speed( one of the segments may be broken)
thats the vibration you are hearing.. and the set its trying to turn on..until you replace the wheel you will be able to watch tv again.
hdtvman
Jul 03, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
GE TV stopped showing picture. Made very loud noise which continued. Now bright white narrow light runs horizontially across screen
can you post a picture of what your screen looks like? Also can you post the model number of your set?
Apr 27, 2008 | Televison & Video
LG 32LC7D Television Logo
75 people viewed this question
Computer Repairing
Computer Repairing
