Question about Kenmore HE5
Found a large gray felt ring dryer - now it rattles
I found a large gray felt ring inside my dryer drum. Now my dryer makes a rattling sound when it runs. What's wrong? Can I fix it?
  • 10,319 Answers
Reattached the felt ring correctly around the drum to make it run quite again
Posted on Apr 26, 2010
We have a Whirlpool LTE6234D Washer/Dryer stack. There is a large rattling noise come the dryer. We took off the front panel of the dryer. The housing of the fan seems to be loose and making the...
Hello & Welcome to FixYa
Awful noise that sounds like its out off balance comes when the belt is either broken or worn out and needs replacement. If you want to do this yourself then you can check this video on youtube:
Sep 22, 2011 | Dryers
Scraping sound from dryer when running
If the sound seems to come from the front of the drum it's probably the felt guides. The bottom one will wear first and make a grinding, rattle like sound. You can access it by removing the front panel which includes the door. It fits around the drum at the front. Here's a diagram. Some models have a two piece and some a one piece guide. Part 4 on this diagram is one. It's called a seal here.
If the sound comes from the rear, there is a nylon bearing and metal socket at the rear center of the drum.
May 31, 2011 | Kenmore 98702 Stacked Washer/Dryer
When it rotates it gives metal banging sound what is the reason?
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 20, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Rattling and very loud
Rattling and very loud sounds like a very worn roller on the belt tensioner inside the dryer. The top and front panels must be removed to replace these items. Remove the top first to inspect. Usually the inner bearing on the roller locks up making the roller to receive a flat spot on it which causes the belt to jump upon hitting the flat spot on the roller. That is the sound of the dryers drum you hear
Apr 17, 2010 | Dryers
The dryer heats fine but is making very loud rattle noise when drum is turning
hi sounds like you need new rear bearing if yes change front felt bearing too....
Dec 30, 2009 | Estate Dryers
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Kenmore dryer keeps making a ringing sound when dryer is on.
If the nois is kind of rattling noise, then it is usually caused by objects (coins etc.) trapped between inner and outer drum. If instead is an high pitched noise that gets louder when the machine spins faster, then it is usually a bad drum bearing.
Jul 14, 2009 | Kenmore Dryers
Kenmore Dryer makes Noise Model 86671100
Very few of the tubs are true to round. You stated it has made the sound since you've owned it. Observe and listen to see if you can determine the closet area to the noise. Usually moveable parts get louder over time. Your problem could be a number of things. I would start by adjusting the bottom leveling feet and be sure it is level front to back as well as left to right. Other items could be drum seal gasket bearing, rear felt seal, rear drum support roller, belt tension pulley, blower wheel, blower wheel housing, front drum glide bearing, shaft drum support roller, bracket for drum support roller, front ring bearing kit, pully on the motor, or even lose cabinet housing bolts.
Use the below link to refer to on how to get inside:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 07, 2008 | Kenmore 22422 Top Load Washer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
ASSISTANCE WITH MY GE-DBXR463EB1WW
two possibilities come to mind. one) the drum bearing is shot! second) the drum rides on two felt and plastic "bearings" at the front of the dryer. these felts might be completely worn causing the drum to flop around.
Aug 21, 2007 | GE DVL223GB Gas Dryer
Kenmore HE5 Logo
307 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
