Question about Dryers
Dropped a plastic pen cap down dryer lint slot on top of dryer. Any way to get it out? Can it just fall all the way through the machine? Can I simply put the lint screen back in and run the dryer or is damage possible? Rubber hose at the end of a vaccuum?
    Novelist:
  • 145 Answers
You may be able to run the dryer with no problems at all but it depends on where the cap fell. It could melt if it gets hot enough. It could also get caught in the blower motor which is used to expel air outside.
Posted on Apr 27, 2010
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
How do I remove the top of the dryer?
They are all attached with clips - just place a long screw driver where the clip is and pry it open taking pains not to scratch anything
Sep 08, 2015 | Dryers
Dropped something down the lint trap
If it's a metal utensil that responds to magnetism, try a magnet on a string, or one of those telescoping magnetic picker-upper tools to get it out.
Jan 22, 2014 | Amana NDE2330AY Electric Dryer
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
I dropped a screwdriver down the lint vent on the top of my 80 series kenmore dryer. Can I still operate the machine without damage?
I would be very careful if you are doing so. Every dryer has a fan that is used to expel your moisture and air out to the outside, and the fan is usually in the same pipe as the lint catcher. I wouldn't recommend using the dryer until you get the screwdriver out but if you want to try it I would listen very carefully for the sound of the screwdriver hitting the fan blades, because if the fan blades are ruined moisture will remain in the dryer and your clothes will not dry.
May 21, 2010 | Dryers
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
Crosley Gas Dryer-small plastic object fell into blower (?)
you might have to take the back off then off to the left take the screws out of the blower houseing and carefully pull it apart and then you should be able to take what ever is in there out
hope this helps
please rate this help
Feb 09, 2009 | Crosley CDG6000 Gas Dryer
Dryer
Your going to have to remove the back panel and then access the filter air chamber. Or get a couple of strong fellows and have them un plug it and then flip it over and bump it a few times and hope it falls out. Dont reast its weight on the control console. Best o Luck
:?) DRRXR
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 01, 2009 | Kenmore Dryers
Dryers Logo
105 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
