Question about Samsung Yepp YP-T9 Digital Media Player
Samsung yp-t9 whenever I connect my mp3 to the comp, it always says 'usb connected'.. then five secs later it says 'usb not connected' on the mp3 screen display. idk why this happens, but it happens constantly and is really frustrating. theen whenever I go to my music files in the 'music' section of the device, it shows ' no file ' in the display. my computer doesn't recognize the device anymore ! what should I do ..
  • 5 more comments
  • CJSneedshelp Jul 02, 2008
    my computer doesn't recognise my samsung YP-T9 mp3 player and I can't get any music on it ... at first he put me to install some service pack 1 but I already have service pack 2 ... please help me
  • suwath Jul 19, 2008
    I plug in YP-T9 to my notebook. It is turned on.. show USB is connected, USD Disconnected, then turn off. These steps are repeated when ever I still keep plugging it to notebook. Only way to stop is to unplug it.
  • Anonymous Nov 22, 2008
    usb connected 5 sec. leter USB not connencted loop.
  • esmisehran Dec 07, 2008
    every time i plug my samsung yp-t9 in to my computer it make the noise that its suppose to but my computer doesn't recognize it any where but it works on my moms laptop
  • Anonymous Dec 12, 2008
    Windows Vista does not have a driver, with windows xp it displays USB connected and few seconds later USB disconnected. MP3 player reboot does not seem to resolve anything. Neither restarting computer. Tested on 4 different machines. I consider trashing the player and getting an ipod.
  • elmagojorel Apr 10, 2009
Player yp-t9j code
Posted on Apr 02, 2008
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
My Samsung YP-T9 MP3 Player wont turn on. I was just listening to it yesterday and it was fine. But today when I pressed the button to open it, it didnt open. I plugged it into the comp to charge it but no...
when that happened to me i plugged it into the BACK USB port of the computer and let it charge for three hours it sould be fine
no clue y the back works and the front doesnt when that happens but it does :P
Aug 26, 2009 | Samsung Yepp YP-T9 Digital Media Player
Samsung yp-t9j freezes at usb connected
I use t9b player for two years and I have never encountered this problem. But if you have access to device memory, you can upgrade firmware to new one.
Mar 17, 2009 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 problem
look buddy first u shud get rid of the shorting out on the usb connection.
then get to samsung.com and check the support page of ur product and start downloading!!
Jan 07, 2009 | Samsung Yepp YP-T9 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Can't connect to my pc
Mine had the same problem and here's how I fixed it :
First, connect your YP T9 to your PC
Once connected, on your PC go to :
-Start
-Control Panel
-System
-Hardware
-Device Manager
Then you'll se your YP T9 appear under either "portable devices" or Universal USB or USB something...And since it's not working properly, you should see a yellow exclamation point besides it.
Then click on the YP T9 with the exclamation point and right click again on it, then press "update driver"...Then follow Window's instruction to update it, it's quite easy...
That should do it! : )
Apr 05, 2008 | Samsung YPT9 Digital Media Player
Samsung YP T9 4GB USB Fault
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall, reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfixIf that doesn't fix it try the USB cable
Jan 24, 2008 | Samsung Yepp YP-T9 Digital Media Player
Problems!
You need to reformat the device and then upgrade it to the newset firmware. You should be able to find instructions on how to do this on the Samsung website.
Jul 31, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung yp t9
Firstly, "re-set" the T9 (ie hold 'MENU' & "REC', for 3 secs to re-initialise the built-in firmware - refer to your manual, or download manual off Samsung website). This procedure will overide everything. If this gets it goin, then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your T8 - your manual should explain how to do this. Always update your T9 with latest firmware when available (appropriate with your Windows OS), to eliminate any bugs in the firmware. Failing this, then a replacement battery is the next step. If still under warranty (ie less than 12mnths old), then have an approved Samsung service agent look at it Free of charge. Good luck.
May 13, 2007 | Samsung YP-T8 Digital Media Player
Samsung Yepp YP-T9 Digital Media Player Logo
284 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
