Question about Belkin F5D8236-4 Router
Are the antennas removable from the router?? - Belkin F5D8236-4 Router
    Guru:
  • 825 Answers
No... belkin routers does not comes with removable antennas...
none of the belkin routers comes with removable antennas....
only the PCI type wifi card comes with the removable type antenna....
Posted on Apr 30, 2010
    President:
  • 1,768 Answers
Depends on the router design.
some routers have what are call fixed antenna.
other have BNC connection some are thread antenna.
some are internal fixed. yes, most can be removed if not soldered to the main board of the router.
Posted on Apr 26, 2010
How i can detach/unscrew D-Link Dir-600M Broadband Wireless Router antenna?
Not all antenna are removable, if it does not easily unscrew, it is probably not removable.
Jun 30, 2016 | D-Link Computers & Internet
Signal not strong enough can I boost it
The "Wireless / Advanced" configuration window contains a setting for transmit power. Be sure it is set to 100%.
Otherwise, your only options are to replace the antenna with a booster antenna, or to add a stronger wireless router as an access point to your current setup. Using a booster antenna requires the D-Link to have a removable antenna, which it may not have -- none of the documentation calls this out as a feature.
Keep in mind that if you are trying to use this router over excessive distances, boosting the router's own power will not necessarily improve your connection, because the broadcast power of the remote PCs is also a limiting factor.
Dec 02, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Is the antenna removeable?
Yes. Typically they can be unscrewed from the back, but each model has its own intricacies, so you may want to look for a specification/data sheet for it.
May 17, 2010 | Dell Wireless 2350 Router
How do I remove the antenna from a Netgear DGN2000, to fit a more powerful one? It doesn't seem to screw on/off, and I'm hesitating a bit before trying to pop it loose with a screwdriver!
Please do not try to remove antenna from this router as it does not support detachable antenna. You might cause harm to the hardware and render it useless. It is not possible to remove/attach antennas on this router.
Hope this helps.
Oct 10, 2009 | NetGear DGN2000-100NAS Router
Router is too far away to hook up
There are a few things you can try to extend your wifi signal.
If the antenna of the router is removable, then you might want to look at antennas with a higher gain, keep in mind they must have the same type of connector as your router. If your antenna is not removable, or this doesn't get you the range you need, then you may want to look into a wireless repeater, this you need to just place at the edge of where your wifi connection drops off, and it will extend the signal by rebroadcasting it.
Cheers!
Jun 09, 2009 | Linksys Wireless-G WPS54G Print Server
Actiontec gt704wg antenna broken
yes, and here is the answer from the actiontek website
Is the antenna on the Actiontec Wireless Router and Gateway replaceable or upgrade-able?
Yes, the antenna can be removed and replaced or upgraded. The connection method is, Reverse Polarity Sub-Miniture Adapter (RP-SMA), is readily available at most computer or electronics stores.
Mar 20, 2009 | Actiontec GT704WG Wireless Router...
Distance from TX to RX possible too great
There are a couple more questions
  1. Is it a removable antenna on the wireless router e.g. 5db or 7db gain. you could just get better antennas to increase signal strength for distance.
  2. E-bay has a linear antenna you assemble with a usb wireless network adapter attached.
Mar 31, 2008 | D-Link AirPlus DI-524 Wireless Router
NetGear WGT624 Antenna
i would just think you twist the antenna
Dec 30, 2007 | NetGear WGT624 Wireless Router
Replacing antenna on linksys wrt54g router
yes u can get a antena from retail store and get it and remove the old one and turn off the router and and connect the new one and turn on the router>rate me solved if its helps thx
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Belkin F5D8236-4 Router Logo
381 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
