Question about Troy Garden
Zama carb runs good until air bubbles begin to fill gas line,, then dies
    Sniper:
  • 52 Answers
You may have a crack in one of the fuel lines. There shouldn't be any air bubbles in the line. Check the lines to see if there's gas leaking from them. If not, you may need to replace the diaphrams and gaskets on the carb.
Posted on Apr 26, 2010
Testimonial: "Been there,, done that, all is fine after lines replaced!! Thanks Mucho Nmiller1"
Zama carb pulls gas when not running
throw the carb out and buy a new one. there is an internal issue that can not be fixed
Mar 20, 2013 | Homelite Garden
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
1979 holiday rv chevy 454 no fuel to carb i replaced fuel pump filters fill carb with gas engin runs then no fuel to carb
if it has been sitting for a long time you may have to dis-connect the fuel lines at both the tank and the pump and blow air through to see if there is a blockage in the line. if that is clear then make sure all fuel hose's are in good condition and not collapsing from old age. if those are in good condition then there is a problem in the tank and it will have to be removed for inspection....
Jul 14, 2012 | Chevrolet Cars & Trucks
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
I am looking for Ryobi brush cutter parts
Any local small engine service shop should have these parts in stock. Its called a 'primer bulb'.
Determine if the primer bulb is part of the carb or sperate from the carb with fuel lines connecting them. If seperate remember how the 2 lines get connected when you remove the bulb and replace with a new one. If a part of the carb...
You need to determine if the carb is a Zama or Walbro. It will have the name stamped on the carb. All Zama carbs use the same bulb. Walbro has a small and large bulb.
It would be worth while to install a new carb kit while you have the carb off and apart
Nov 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
312 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
