Question about Canon NP 6545 Copier
How to settings user ID - Canon NP 6545 Copier
    New Friend:
  • 170 Answers
Just press * ,id,stop,* then you will see the selection of how to set the user id
Posted on Apr 26, 2010
  • rhico Jun 03, 2010
    just press * id stop * then follow the instruction appears on the screen
Find friend
You can search for your friends by using their Skout User ID, find them on Skout and chat away. But first, you have to create your own, unique, Skout ID. So how do you set your Skout ID? Don't worry I will teach you how to set your Skout ID and finding your friends with theirs.
To set your Skout ID, go to the chat window and tap Find Users, Tap Set my Skout ID and type in Skout ID you would like. Keep in mind; they are unique, that means there can only be one JoeSF so choose quick before someone else does.
If you are looking for someone, tap Find Users and type their Skout ID into the search box. It's that easy!
But wait, Have you forgotten what your Skout ID is? In your profile tap Edit and then Info - voila, your Skout ID! Contact skout for more issues
Dec 30, 2013 | SKOUT
Router was reset and is now showing limited connectivity
After reset you have to configure the router for internet setting.
Type the url 192.168.1.1
It will ask for user id and password. Keep user id blank and type password as admin.
It will open your router setting. Configure your setting.
Thanks for using FixYa.
May 18, 2011 | Linksys Wireless-G WRT54G Router
Can you add a new fax no that shows in the header for outgoing fax?
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
Feb 03, 2011 | Panasonic Panafax UF-585 Plain Paper Laser...
I need a user id.
The user id is whatever you programmed it to when you set the router up. IF this was setup by your service provider then it is whatever they use when they set up routers. In most cases the factory sets them to "admin" with a password of "administrator". Hope this helps.
Dec 13, 2010 | Computers & Internet
Windows cannot load the locally stored profile. Possible causes of this error include insufficient security rights or a corrupt local profile. If this problem persists contact your network administrator.
It looks your profile is corrupted. You can login with administrator's login id other than the local profile user id and rename the old profile located in c:\documents and settings\ your user login name folder
and rename the folder. After that logout and login again with your user id, one having problem with profile and again go to the c:\documents and settings\ your user id name folder which you renamed and move your critical data on desktop or my documents to the new profile.
May 14, 2010 | Microsoft Windows XP Professional
How to set up WEP password for my Motorola WR850G wireless router?
I got this info from the online User Manual:
  1. go to web address http://192.168.10.1/
  2. Enter the User ID. The default factory setting is "admin"
  3. Enter the Password. The default factory setting is "motorola"
  4. Click Control Panel > Device Security
  5. In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive characters as well as numbers. It cannot be longer than 64 bytes.
  6. In the Login Password field, enter your Login Password. Create a password that contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
  7. Re-enter your Password.
  8. Click Apply.
  9. Once the settings have been accepted, click Restart and log back into the Configuration Utility using your new User ID and Password.
  10. Select Wireless > Basic.
  11. Change the SSID to a user-friendly name and click Apply.
  12. Navigate to Wireless > Security.
  13. Select WPA-PSK from the ESS Authentication options.
  14. Select TKIP from Encryption Status options.
  15. Click Apply and then click Restart. Your wireless security configuration is now complete.
WEP is easily hacked by hackers. WPA-PSK with TKIP encryption is the newest, most secure wireless security measures and you can follow these directions to set it up this way.
Hope this helps you out! If so please give me positive rating (4 thumbs up)
Jan 03, 2010 | Arris Wireless G Broadband Router (wr850g)
Deleting and adding new users/passwords
try this: for IRC 3200 ,press asterisk with head press(near ?button)> ID SYSTEM setting> Dept ID management, you can add/delete Dept ID
Jun 18, 2009 | Canon imageRUNNER C3200 Color Printer
Copy limit
the only way is to goto additional functions > System Settings> dept I.D > set a user code and password, then you can set a copy limit per user id, once a copy limit is reached you have to reset it or create a new user I.D. Thats the only way, you can also get reports on how many copies each I.D has done..
Hope this helps
May 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
User Code
You may want to print this out because it is long.
Adding codes
Adding codes is really pretty simple.
First Add a System Manager code:
  • Press the 'additional functions' button to the right of the touch screen.
  • Press the 'system settings' button ON the touch screen.
  • Press the 'system manager settings' button on the touch screen.
  • Press the 'system manager' button on the touch screen and then use the touch screen to enter the system manager's name. Press 'done' when you have finished.
  • Press the 'system manager id' button on the touch screen and use the numeric keypad located to the right of the touch screen to create the id.
  • Press the 'system password' button on the touch screen and enter a numeric password for the system manager. YOU SHOULD MAKE A NOTE OF THE SYSTEM MANAGER ID AND PASSWORD, AS THIS WILL BE NEEDED TO CHANGE SETTINGSLATER.
  • Press 'next' on the touch screen.
  • Press 'email address' to add an email address for the system manager.
  • Press 'contact information' to add an extension to reach the system manager at.
  • Press 'ok' to complete the process.
  • Press 'done'.
Next add user codes:
  • Press 'system settings' button on the touch screen.
  • Press 'department id management' on the touch screen.
  • Press the 'on button' on the touch screen.
  • Press the 'store dept. id / password' button on the touch screen.
  • Press 'store' on the touch screen.
  • Press 'department id' on the touch screen and then enter a numeric code using the keypad.
  • If you want additional security you can also set up a password by pressing 'password' on the touch screen and, using the numeric keypad again, enter the password. The password can be left blank if desired.
  • Additionally you can set an impression limit for that user by pressing 'impression limit' on the touch screen.
  • Press 'ok' on the touch screen to add the user.
  • If you wish to limit impressions then you must press the 'limit impress.' Button on the touch screen.
  • If you want to add more users at this time go back to step 6.
  • Press the 'done' button.
  • Press the 'off' button at the bottom of the touch screen next to 'accept jobs with unknown id.
  • Click 'ok' to complete the process and start using the copier or go back to step 5 to add more users.
After this process users will have to enter a user id to use the machine. At the end of the copying process users should press the 'id' key located at the bottom right of the keypad to logout. The machine will automatically log users out if there has been no activity for a few minutes and this can be changed by pressing 'timer settings' in the additional functions.
While this seems like a lot it actually doesn't take very long to do. There is a far more elegant set of instructions in the 'reference guide' that came with the machine, which includes pictures, and starts on page 4-2.
Nov 07, 2007 | Canon NP 6050 Copier
Canon NP 6545 Copier Logo
82 people viewed this question
old marine
old marine
