Question about Samsung HL-S4666W Television
Where is fan#2 located on model hl-s4666w - Samsung HL-S4666W Television
In general its the lamp fan
Posted on Apr 26, 2010
White Dots, 13 in past month, what's going on...
you have many white dots in your tv screen but you can stil see the picture if this is your problem your dmd chip is defective this will be very expensive to repaire and to complicated this needs to be repaired in a repaire shop
Oct 29, 2011 | Samsung HL-S4666W Television
Samsung hl-s4666w dlp won't come on...
hmmm..not too cool..check all cables, and power source first, yes?
Apr 18, 2008 | Televison & Video
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
Tv repeatedly starts at and shutts down. Lamp come on but then shuts down
Those lamps build up a internal resistance and they get to the point where it will not come on at all, replace the lamp, and you will be good.
Oct 18, 2010 | Samsung HL-S4666W Television
Samsung hl-s4666w DLP "Check Fan #2" on-screen message appears before shutting off. How do I fix this?
Look at the Large Lamp fan and if it is not rotating it is bad and needs to be replaced. If is ok then check the other two smaller fans. You do have a bad fan.
Apr 03, 2010 | Samsung HL-S4666W Television
My HL-S4666W's screen picture freeze whenever I turn it on
If the tv has a built in discoder, it is the decoder at faulty, bypass the decoder using a dvd player, and if that plays then it will prove the decoder fault, the dvd signal is stronger than an external source, oh, by the way, unplug any source of dish/arial etc to the decoder, giving the dvd master control of the tv
Jun 07, 2009 | Samsung HL-S4666W Television
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Fan number 2 in model hls5086w projection tv
the fan may be ok it may be another component thats caused the problem? if you have a meter check the fan you can also get intouch with the manufactuer they will try and help you
Mar 29, 2009 | Samsung HL-S5087W DLP TV
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Samsung HL-S4666W Television Logo
204 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
