Back to:
Tags:
Amplifiers and Preamps
Generic problem for all Amplifiers and Preamps
Losing Preset information
posted by cooldude66 on Mar 23, 2008
My RSX-972 no longer retains the programmed settings if I switch off the unit at the power button. It used to retain all the settings previously. Is there a battery internally that I need to replace, or is the problem something else?
Thanks,
Kevin
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 24, 2008
Not Rated (0)
robotek
Rank:Guru Guru
Rating: 90%, 678 votes
Ho Cool
It will need a supercap or back up battery replaced. Do you know what these look like? Will be in proximity to central controller chip(on the front panel alot of the time. Looking for a cct to tell you exactly where.. back to you soon.
regards
Graeme
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Losing Preset information:
I don't want to Accept this solution
Can you Help with these Amplifiers and Preamps problems?
Crown XTi 2000 2-Channel Amplifier
when its first turned on it works great, then it cuts off,...
I got this ampilfier used and i can't seem to understand...
I'm having difficulty removing the battery from my yamaha...
Sony TA-E9000ES Amplifier
Hi, I'm having a problem with my sony deck. Ok my amp...
Lexicon MC-1 Amplifier
My preamp lost all power. I just had it repaired recently,...
Loading problems.
Repair Service
Find Amplifier and Pre. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
