Question about Uniden Cordless Phone
Phone problems cannot get a dial tone cannot receive calls
  • 1 more comment
  • Anonymous Mar 25, 2008
    had this phone for 1 year.,,,can't get a dial tone. Any solutions or advice?
  • KELLYE SUE Mar 28, 2008
    THIS IS A BUNCH OF ****. WHY WOULD YAL CLOSE YOUR HOT LINE AT 5 PM!!! THAT'S WHEN MOST AVERAGE PEOPLE ARE AT WORK ON THEIR WORK PHONES, NOT THEIR PHONES THAT WANT WORK THAT THEY PAID MONEY FOR!!!!!!!
  • Anonymous Oct 03, 2008
    remote phones indicate "connecting" and then "unavailable". Baterries and main phone seem to function o.k
I'm unable to get a connection on my phone when i press the talk button is says connecting and then it states unavailable.
Posted on Sep 29, 2008
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
https://iihelp.iinet.net.au/Troubleshooting_Home_Phone_for_No_Dial_T...
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support Forumsforums.cox.com/forum_home/phone_forum/f/6/t/3496.aspxJan 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
Jan 10, 2016 | Lands Phones
Dial tone nortel phone
It\'s in system programming: feature CONFIG, Terminals & Sets, enter ext #, Prime Line: set to I/C (for intercom dial tone) or Line xxx. It is probably set to None based on your description.
Aug 26, 2014 | NorStar T7316E Corded Phone
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Jul 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Uniden Cordless Phone Logo
408 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
