Question about ASUS EEEPC900BLK Netbook
Partly green screen on the right side of my laptop computer
Why would my laptop computer screen be turning partly green on the right side and how do i get the green off so i can i have a normal screen
    Sergeant:
    Champion:
  • 305 Answers
You may be close to a strong magnetic field ie tv or sterio speakers ect move away from magnetic source some tv engineers or com engineers have a wand type tool thats moved over the screen which will restore it or sometimes you just wait and eventually it will right its self.
hope this helps.
Posted on Apr 29, 2010
My screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 20, 2013 | HP Compaq Presario CQ50-210US Notebook
Screen wont come on, on my Toshiba laptop computer
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
I have a laptop toshiba l500d series. My question is the screen turns green only the black parts all the time. What would be causing this problem. Thanks
Hi, the screen may turn green when the Graphic Driver is corrupted. Please re-install the Graphic Driver in the Computer. The Graphic Driver can be downloaded from the Laptop Manufacturer website. Restart the computer after installing the Graphic Driver. If the issue persists, restart the computer and try pressing F2 Key to enter BIOS (Basic Input Output System) setup, then check if the screen displays green color. If the screen displays green color in BIOS setup then the issue is related to Hardware of either display or graphic card of the Laptop. In this case, please contact the manufacturer of the Laptop to initiate the service under Warranty. If the laptop is not under Warranty then service charges may apply.
Apr 17, 2011 | Computers & Internet
There are two blinking green lights that will not go off. The computer screen is dark. when i press the turnoff button, the computer green light on the right hand side of the computer continues to stay...
Unplug the laptop and remove the battery. The discharge the laptop by pushing the power button for 15 seconds while it is unplugged and does not have the battery installed. Then put the battery back on and power it up, and use your laptop as you normally would.
Nov 08, 2010 | Dell Latitude D600 Notebook
Hello, i have an asus laptop, model X58L. i was on the laptop when suddenly on the right hand side of the screen there is quiet a chunky bit of a green streak coming down, turning some of the screen green?...
You will have to replace the screen they are usually around £70 to £80 however if you search around you can get it cheaper. If its under warranty get it replaced free. The reason it has happened is usually one of the connections gets damaged or overheats and it kills that side of the screen.
Feb 22, 2010 | Computers & Internet
I have a light flashing from green to orange on my laptop
no worries its just reading.. datas..
hot is just normal..
Sep 25, 2009 | Dell Latitude D610 Laptop Computer -...
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
ASUS EEEPC900BLK  Netbook Logo
264 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
