Question about RCA D52W23 52" HDTV CRT TV
I installed a convergence repair kit in my tv. I left the back and panels off while I test it. Now it will not turn on.
    Sergeant:
    Champion:
  • 431 Answers
CHECK YOUR SOLDER CONN. ON IC'S CHECK PICO FUSES OR LOW VALUE RESISTORS ON CONV. BOARD
Posted on Apr 30, 2010
I have a Zenith R49W36 and i had convergance problems. I ordered the tv repair kit and replaced the parts and now the television continously turns on and off. Please help.
if the TV was coming on before you installed the kit, the logical thing to assume is that something you installed in that process is at fault.
The most likely place to look would be at the pins of the convergence chips themselves.
Look for a bit of sloppy solder where two pins may have got shorted together.
Or just as likely, a pin that was left unsoldered.
both of these issue could be causing your shutdown problem.
Apr 12, 2011 | Televison & Video
AV-48WP30 - Is this a convergence board issue?
yes u r right that is the problem of convergence in your televisions.and it needs to be replaced to make it proper.
thanks.
Oct 29, 2008 | JVC AV-48WP30 48" Rear Projection...
I had to adjust the convergence. But if I turn the TV off, the convergence is off again when I turn the TV back on.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Samsung HCN653W 65" Rear Projection...
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
I can adjust the convergence where all the crosses look good , but at the edges left and right picture is misalligned.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS,and all those resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.Replaced what in the kit,ur tv will be back to normal.
Jan 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Magnavox 51" Projection TV Red Convergence
he is most likely trying to rip you off. You need to replace the convergence ICs. Theres a kit at the following link for your model that has both ICs and the 12 feed resistors plus step by step instructions to do the repair. Heres the link. this is the kit your model uses. http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
A convergence problem such as your describing can blow a fuse if you try adjusting it when the ICs fail. and its all centerd on the SSM panel the LSB panel wont be affected. Alot of TV repair men dont have a clue they just try to sell you some boards instead of repair the issue.
Feb 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
When i turn on tv the screen is turning green
Solution:
Screen looks 3D
Dec 11, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Picture problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Oct 28, 2007 | Hitachi 53SWX01W 53" Rear Projection...
RCA D52W23 52" HDTV CRT TV Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
