Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My televison does not have the red, white, and yellow aux ports. how can i hook up my ps2 and dvd player?
  • 80 Answers
Does it have a 21 pin scart and or s 5 pin plug you can buy these cables.
Posted on Apr 26, 2010
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
How do I hook my old PS2 to my RCA TV with my converter box?
RF cable coax out to TV from the RF Modulator .....RCA jacks "red-yellow-white from ps2 to RF modulator "its not called a converter box"//lol Put the TV on channel 3 you should see the ps2 screen. Same way you would hook up a DVD player to a CRT TV..heres a video
TVs DVD Players How to Connect TV DVD Player VCR With Modulator
Mar 22, 2015 | RCA Televison & Video
How to hook up dvd player to sanyo 42" tv?
LOOK at back of the tv ,you will see an aux port yellow for video white and red is for audio
Aug 18, 2011 | Televison & Video
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Mintek Portable DVD Player
On your TV IN .. Yellow is Video, Red is 1 Audio. White is Audio 2 this is for Stereo if Mono white is not used.Your TV then needs to be set to Aux or Imput.If no button on TV use UP-Down Chanels. Good Luck.
Sep 05, 2009 | Mintek MDP-1760 Portable DVD Player
Cant find channel for playstation 2
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
Cant get dvd to operate
Have you changed the TV input to AUX? If there is a VCR hooked up with your satellite box it has to be on Line or Aux too. Make sure these are in place before trying the DVD player
Nov 18, 2008 | Zenith B27B40Z 27" TV
Can u hook ps2 to dual xdvd700
No you can not hook up a ps2 to the dual. It hads audio inputs but no video inputs
Oct 09, 2008 | Jensen VM9510 Car DVD Player
DVD and PS2 in Black and White
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
About installing my cd/dvd player to my console
This is a bit confusing. You cannot hook a CD/DVD player up to the PS2 console. If your trying to figure how to hook a PS2 console and a CD /DVD player up to a AV system. you need to hook the PS2 Yellow, White and Red cables to any input. Not just a DVD or CD input. Yellow is Video you need that. Hook the red and white to the same selected input.
Dec 01, 2007 | Sony PlayStation 2 (PS2) Console
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
