Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Top is frozen lower shelves food is dethawing
Top shelf is frozen and has ice on it, lower shelves the food is dethawing. I have unloaded and unplugged, Checked underneath but don't see ?? anything
    President:
  • 949 Answers
One of two things is going on here, either the door is not closing properly (or some one left it open), check the seal all the way around especially at the bottom.
Or most likely you have a refrigerant (freon) leak that has left the charge low enough that you are unable to get it to cool throughout. A leak on this type of unit is usually in the evaporator in the corner where a weld was made. The evaporator is about $189.00, with refrigerant a new drier and supplies I bet it would run about $450.00 to repair.
Posted on Apr 26, 2010
Have a upright freezer and the meat on the top shelf is thawed out but the rest of the food on the lower shelves are frozen. Is it a vent problem
Either the door seal is bad or the freezer has a refrigerant leak or a bad compressor. Best to have an appliance tech check it. It won't take him long to locate the issue.
Nov 04, 2017 | Freezers
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Freezer is not even keeping ice cream from melting..and the 2 slots at the top in the back by the top shelf?? Are filled with IVE
Do an old fashioned dethaw of your icemaker. Remove food in compartment, unplug or turn off freezer. Leave doors closed, and get a thick towel and a pot of boiling water. Place the towel under the pot, close the door, and let the heat from the pot warm up that frozen freezer vent. That will clear the ice so the fan can draw cold air out into the freezer
Aug 01, 2014 | Samsung RS261MDPN - 26 cu. ft. Side by...
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
Only upper section of the freezer works, heavy ice-buildup.
The symptoms you are describing are typically from a refrigerant (freon) leak. Unfortunately it will be as simple as adding new refrigerant as it will just leak out. The leak will need to be repaired. From my experience with this unit my best guess is that the evaporator coils would need replaced. An average repair cost for this type of repair would be around $400.00.
I hope this helps.
May 06, 2010 | Woods Freezers
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Upright freezer not cooling
The model number would help but it sounds like a sealed system leak or restriction. If thats the case I would not suggest trying this yourself. The water should freeze overnight and the frost should keep going to all the shelfs that have coils in them.
Apr 16, 2008 | Freezers
Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
Dec 07, 2007 | Freezers
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
247 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
