Question about Whirlpool GHW9100L Front Load Washer
Kenmore washer 110.24642300 will not spin or drain
  • 5,911 Answers
The model number you provided is for a Whirlpool manufactured TOP LOADER. If this is correct, check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 3949238.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If you would like to purchase a Repair Manual to assist you with all your repairs, repairclinic.com has one that you can order on line for about $20. The part number is 1170635. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on Apr 26, 2010
Testimonial: "Thanks for the information. That wasn't the problem. When it's on spin cycle the machine make a noise and doesn't spin nor drain."
the dr
  • 447 Answers
SOURCE: kenmore washer drains but won't spin.
Sounds like the motor coupling has broken, fairly inexpensive part but does require some finesse to install. let me know if you decide to attempt it.
Posted on Oct 15, 2007
aborcass
  • 2651 Answers
SOURCE: won't spin out water
sounds liek you have a bad clutch assy, not engaging fully, tip the machine back and give a look around teh inner perimeter of the cabinet, do you see brownish oily streaks dripping down, perhaps a pool of oil under hte unit??? if so you need a new transmission(5 year warr) and clutch assy
Posted on Mar 23, 2008
reg501
  • 413 Answers
SOURCE: kenmore washer 24642300
The lid switch has failed. To replace lid switch;
REMOVE POWER, lift the console by removing the trim on either side. Grasp the top of the trim and pull forward to expose a screw. Remove both screws and lift console.
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The lid switch can now be accessed and replaced.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
huuum
  • 750 Answers
SOURCE: KENMORE 110 -LETS WATER IN..DOES NOT SPIN
Hello Sylvia,
You said,
HELLO...I HAVE A KENMORE 110 WASHER, LETS WATER IN BUT DOES NOT SPIN. PLEASE HELP. SYLVIA
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin.
The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts.
If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed.
As the clutch wears out, it may prevent the unit from spinning well or at all.
If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and draining, the other.
It's possible for a motor to burn out in one direction and continue to operate in the other.
If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool®
have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective,
the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized.
These components allow the inner tub to spin freely inside the outer tub. When this is the problem,
you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety,
washing machines are made so that they spin only with the lid closed.
The lid switch prevents the spinning action when the lid is up."
Bless You,
Please give me a good rating for the sound advice , before you sign off.
Thank You
Posted on Sep 17, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore washer no spin
Does the washer drain the water quickly?? Are there any error codes?? Usually the drain pump sump is clogged and not draining, thereby not letting the unit advance to spin.
Nov 23, 2007 | Kenmore Elite HE4 Electric Dryer
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Washer not spin
I have a Kenmore 60 sirce washer it drains put won't spin
Dec 07, 2013 | Kenmore 24032\24036 Top Load Washer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool GHW9100L Front Load Washer Logo
937 people viewed this question
Dan Webster
Dan Webster
Sal De
