Question about Maytag MMV5165 Microwave Oven
My maytag mmv5165 microwave oven just started acting up. Whenyou close the door, the light stays on and the turntable moves, but the magnatron isn't running. I push the stop button, but it keeps "running" anyway.
    Habit-Forming:
  • 193 Answers
Interlock switch
Posted on Apr 27, 2010
Why does the microwave have the turntable keep moving/light stay on/keep vibrating whenever the door is closed?
< - contact me directly for free advice.
Remind me of your exact symptoms and the full model number from the tag in the cooking cavity or elsewhere on the oven.
May 10, 2014 | Sharp R-530ES Microwave Oven
Maytag microwave model mmv1153baw light won't shut off and won't start
Either the latch in door (spring related) is not in the correct location or you have a door switch issue and its not expensive to fix if you husband is handy. Part number you can use is 28QBP0495 or the factory one 3405-001034 (more expensive). This issue is common and these switches are located inside the control panel on the left side, the switch you seek is the lowest one in the bracket of three. Good Luck and I hope this helps.
Apr 20, 2014 | Maytag Microwave Ovens
Maytag microwave "turntable", light and cooling fan stay on after cooking complete.
you can leave the door ajar for a change - it also eliminates the odor inside the microwave
Oct 26, 2012 | Maytag JMC9158AA Microwave Oven
Microwave wont heat
If it has a turntable does that move? If it moves and does not heat suspect inverter board (power) or less likely the Magnatron.
If table does not move it could be a issue with the safety switch which the door engages when closed.
Oct 14, 2012 | Whirlpool MH6140XK Microwave Oven
Mm5165bas, light comes on, fan works,carousel doesn't work , does not heat.
Hi, it sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnatron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnatron, they replace the whole oven.
There is a possiblity that the circuit that provides power to the magnatron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it appart. It is a fairly lengthy process however.
May 08, 2011 | Maytag MMV5165 Microwave Oven
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
Maytag Over-the-range microwave runs but does not heat Model MMV4205BA. Light works, turntable works, timer works. But no heat
Please remove the cover and check the door safety interlock switches. Check with a contunity checker or a volt ohm meter.
What happens is thjis: when the oven is running ane you open the door, the tiny contacts in these little swirtches arc and burn. Eventually, the switches fail. When this happens, the oven doesn't know the door is closed. When The door is open, the oven will not turn on the magnatron. No magnatron, no heat.
It could be the start capacitor, but not likely compared to the switches. Dont try to service the capacitor unless and until you understand the danger.
Thanks for posting your question at FixYa.com - please vote.
Thanks
a
Nov 14, 2009 | Microwave Ovens
Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
May 15, 2009 | Maytag MMV4205 Microwave Oven
Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Maytag MMV5165 Microwave Oven Logo
144 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
