Question about Compaq Presario M2000 Notebook
Recently added windows7 to my presario and also an additional ram stick...but I am having trouble with my laptop it will only start in safe mode but wont let me do anything...there is no restore point...I don't have a disk anymore....it freezes eachtime I try to open it in regular mode....I have re-installed a few different operating systems but all have system failure...what can I do? I need this computer for school
  • 30 Answers
Hi well the problem is the ram you installed a ram that isnt recongnized and or is not compatible with the mother board remove the ram stick and put back in teh factory and see if it works if it does then its the ram
sorry if dont periods and stuff i type really fast and i answer 100s of posts every hour
Posted on Apr 26, 2010
The computer will go to start up screen but it justs restarts to the start up screen comes up again
1. if you have recently attached anything to your computer detach it. (new mouse, keyboard, maybe you added a new ram-stick)
2. unplug the computer and start fresh.
3. attempt to boot in safe mode and do a system restore, or boot the windows disc and try to repair the problem.
Mar 30, 2011 | AOpen Computers & Internet
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Bsod when adding 1gb of ram to my compaq 2200 laptop
jayson30
In regards to the memory issue the problem is that your notebook only support 1gb of memory so you will have to split it between 2 512 sticks as that is the max the computer can handle. This is why the system blue screens with the 1bg stick.
Let me know if you have any more problems or questions
Issken
Mar 04, 2010 | HP Compaq Presario 2200 Notebook
Toshiba A250-s4707 only work in safe mode windows7, becase freze en normal mode
you need to work out what is causing the issue. did you recently install something that caused this to happen? try a system restore to a checkpoint before the error occured but be aware you will lose files unless you create a cd image of the system.
Feb 25, 2010 | Toshiba Satellite A205-S4617 Notebook
WILL NOT RUN
It's a hardware conflict,Have you recently update your ram or other hardware?
Is the fan running?
Have You tried to start in last known good configuration?
May 09, 2009 | Toshiba Satellite A55-S306 Notebook
Adding an additional memory module to laptop...wont start!!!
The problem is that your laptop only supports 2 GB of RAM. If there is not a newer bios allowing more then 2 GB is the max you can go. Since you put the 2 GB in one slot then the other slot will be useless. It wouldn't matter how much you put in the 2nd slot because the bios already says you have 2 GB on board and will not accept anymore. Sorry.
Apr 08, 2009 | HP Compaq Presario C500t Notebook
My laptop(os windows xp) is infected with iiiiii.exe virus.
first thing to do is try to install and scan your pc with an antivirus program...if you have one already...update your antivirus program. restart your laptop and press F8 to enter safe mode, in safemode, start a full scan.
when finished, reboot back to normal mode then download CCleaner. Scan you laptop using CCleaner to remove the temp files and fix registry issues, you can also disable the startup programs that you do not need to start automatically in CCleaner.
CCleaner
In Addition, you could also install a antispyware program like Ad-Aware just to make sure.
Hope this helps.
Feb 04, 2009 | HP Compaq Presario v3000z Notebook
Just want some more memory
Getting additional memory The below commands will help allow your computer to load programs into memory more efficiently allowing you to have more memory for MS-DOS programs / games.
Ensure you have the below three lines at the beginning of your config.sys file.
DEVICE=C:\Windows\HIMEM.SYS
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.EXE NOEMS
By placing the DOS=HIGH,UMB on the second line, this can, in some cases, save memory because it is loading DOS into upper memory before loading the memory manager. Additionally, the first and third lines cannot be loaded into high memory because these lines are the memory managers.
Load all your devices in your config.sys and autoexec.bat into high memory.
Dont for get to Vote / Merry Christmas....Good Luck!
Dec 06, 2007 | Compaq Presario 5000 PC Desktop
Laptop start up problem
go into bios and turn off virus i assume you have xp
Oct 25, 2007 | Compaq Presario V4000 Notebook
Acer Aspire 3100 boot up problem
unless it is something more serious, first keep pressing F8 when you turn on the notebook and it should enter safe mode. When in safe mode select the operating system that is highlighted and then a screen will appear with options, one being 'Last Known good Configuration', highlight this and press enter. The system will reboot and start again in windows as normal hopefully. If you are not able to get a screen showing in safe mode there is something more serious wrong and it could be hard drive fault or motherboard, but if you can see the disc drive light flickering the system is loading and you may have a graphical fault.
Aug 09, 2007 | Acer Aspire 3100-1405 Notebook
Compaq Presario M2000 Notebook Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
