Question about Salton Coffee Makers & Espresso Machines
I obtained salton coffee grinder model CM-4 but the inner grinder wheel cover is missing.Is it still avail.?Thank you.
4 Suggested Answers
SOURCE: salton coffee mill model cm-4
http://www.mrcoffee.com/Products.aspx?cid=44&Page=2
this link had few products and manuals,see if you can find yours..
Posted on Nov 23, 2008
skyblue67
  • 71 Answers
SOURCE: Missing user manual
Hello you can download your user manual directly from here
http://www.krupsonlinestore.com/manual/55351.pdf
Posted on Jul 25, 2009
SOURCE: Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Posted on Oct 08, 2009
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Grinder gets clogged after several uses
You should clean it with a brush After every use.
Feb 14, 2011 | Salton Coffee Makers & Espresso Machines
Glass carafe for Salton espresso/cappucino machine EX-99
If you are still looking for the espresso carafe for the Salton EX-99, I have a white one with the matching lid available. I can be reached at cowboy_romeo@yahoo.com. If I don't hear back from you in the next day or so, it's going to Ebay. Thanks!
Sep 05, 2009 | Salton Coffee Makers & Espresso Machines
Missing user manual
just shearch your cas manual though google and it should come up straight away and you can download the manual for free i done it for my cars manual hope this helps
Apr 14, 2009 | Krups GVX2-14 Burr Coffee Grinder
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Salton perfect touch electric grinder - thermal switch/fuse
This is most likely a thermo overload, and can be replaced, make sure that there is no short circut before replacing it, as it will only blow again if there is a short. This part can be purchased at any Radio Shack store.
Jan 26, 2008 | Salton Perfect Touch Electric Blades...
How does one order a replacement grinder cover?
you can now order a replacement filter basket for this coffee maker. The price is $8.50 plus shipping and handling. Just call customer service at 1-800-233-9054.
Dec 09, 2007 | Salton MEMB1B
Salton "three for all plus" coffee espresso maker instructions
the following site will take you directly to the salton info file. site says if you email them they will get you an instruction file. http://www.singleservecoffee.com/archives/000517.php
Sep 21, 2007 | Salton EX20 Coffee Maker, Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
