Question about Garden
What oil filter should be used on a Honda 3813 mower?
  • 1 more comment
  • judy1234169 Apr 26, 2010
    Can it be cross-referenced with Fram or any parts store filters?
    I need an oil filter.
    The answer was about an air filter, not an oil filter.
  • 4,066 Answers
Description: AIR FILTER HONDA / 17211-ZAO-702 Replaces (OEM): HONDA 17210-ZAO-506 HONDA 17211-ZAO-702 Fits Models: HONDA HT 3813 and 4213 tractors with GX360K1 vertical engines Length: 6 7/16" L Width: 4 1/8" W Height: 1 3/4" HT Pre-filter included Honda code 2893923/5168273 Riding Mower Air Filter Fits Honda
Posted on Apr 26, 2010
What oil and oil filter do I use for my riding lawnmower.
30 weight oil is fine. as for the filter..I would suggest that you bring it to a shop and match it up, or go on line to manufacture.
Oct 09, 2014 | Garden
I have a honda 3813 riding mower. When i try to start it,it backfires a litttle but will not run.?
Backfire usually means that it is out of time. This sometimes happens when something is hit causing the flywheel to jerk shearing the flywheel key. Remove flywheel and replace woodriff or slot key.
May 11, 2014 | Sears Garden
Oil in air filter
Replace air filter, remove carb bowl, clean carb with carb cleaner. Reassemble. Clean holes in carb bowl screw.
Apr 02, 2014 | Honda Garden
Lawn mower oil leak
is the engine smoking out the exhaust or by the filter if it is coming from exhaust sounds like a ring problem
Jun 05, 2013 | Honda Garden
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Does the Honda 3813 take a positive or negative ground?
Most all garden tractors here are negative ground. I have seen only a few things positive ground, and that was an old land rover and old jaguar, Both british made. I couldn't find any reference to it being different. Hope this helps.
May 10, 2010 | Garden
Oil coming out of the carburetor of my Honda Harmony 215 mower
unless the ground was a steep slope while mowing or the mower was tipped over 35 degrees or more in any direction except with the handle bars down (spark plug up is ok), it will most likley be a blown head gasket between the pushrod gallery and cylinder. remove the head and get it re-faced then assembly with new gasket. valve adjustments are 4 thou inlet and 6 thou exhaust
Jul 18, 2009 | Garden
Need to change the motor oil in my lawn mower, **** Super Z with Honda 24 hp motor. How many quarts of oil does this require?
You should have a GXV670 Honda on that beast. If so, then 2.5 quarts with a filter change.Good luck.
Jun 26, 2009 | Garden
I am looking for sevice bulletins for honda 3813 lawn tractor
I had a similar problem with my Honda 3813. When I tore it down, I found that the 3813 has a slow delay cyclinder - something like a shock absorber - the slowly puts pressure on the clutch plate after you let up on the clutch pedal. In my case, the clutch is old and worn, this is exactly the symptom I experienced because the clutch was nearly worn out - it took like 10 or more seconds to get going. A new drive clutch and a little adjustment fixed this problem for me. To replace the clutch without removing the engine I had to cut the cross brace plate on the bottom of the tractor.
To get to this you need to remove all the tin that is under the seat part of the tractor - a real nuisance.
Also, it took me 3 months to get the clutch from the Honda dealer. .... definitely not helpful! Good thing I had a John Deere as a backup, I've never had trouble getting parts quickly for that.
Mar 13, 2009 | Garden
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
