Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire model ltf2140eso, the lights continue to flash on the front of the machine when not in use
  • MS_WI_3013 May 11, 2010
    Clarify. If you press the cancel button, do all the lights go off. then come back on with out any user intervention? And what lights are flashing? all of them or specific ones.
ginko
  • 19396 Answers
SOURCE: All lights flash on front
Try first unplugging the power cord for thirty minutes.
If the error does not clear then it is probably a faulty control panel.
When the fault is on a different part (eg. pump, sensor etc.) you get an error code.
You can find the replacement control/timer assembly here.
If you need to call repair service you can use the number printed at the end of the owner manual.
Posted on Sep 13, 2008
onthejob5130
  • 640 Answers
SOURCE: Frigidaire stackable front load washing machine
ok we have to take bottom front panel off,,theres three torex head screws..now straght in front of you is the pump ,,remove the filter turn it counterclockwise,,theres always a little water in it so be prepared...remove clogg and we should be good all coins are mine,,onthejob
Posted on Feb 07, 2009
  • 240 Answers
SOURCE: Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Posted on Apr 29, 2009
SOURCE: Frigidaire LTF2140ESO front load washer
are the controls locked? my son messed with my washer and then it wouldnt work but it was only locked. I didnt even know that it locked until i searched the manual and found that if you hold in the Options and select buttons at the same time, it will either lock or unlock the washer!!!
Posted on Mar 02, 2010
  • 523 Answers
SOURCE: Door lock light flashing, door will not open
if it has a kick plate on it take it off and see if the filter is clogged
Posted on Apr 21, 2010
The start button keeps flashing
Hey friend, thank you for your post!
I understand that the start button on your Frigidaire washer continues to flash. This could be indication that the control panel has been paused or is miscommunicating. I would recommend performing a reset on your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you continue to receive blinking lights your control panel may need to be replaced. This however is not a simple DIY job and I would advise you to contact a professional technician for proper repairs. If you do not have a professional contact I would suggest looking over your manufacturer's website. Hopefully this helps to some degree. -Matt
Feb 12, 2015 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Washer acting strange
when lights flash the unit is indicated an error message, count the blinks and which lights are flashing, then seek out online what error could be. also, very common issue is clogged drain hose filter inside machine, service company should be contacted to properly take apart unit and repair.
Apr 03, 2013 | Frigidaire Washing Machines
Washer won t start and no water flows into it but light is on
Similar issues here.I removed the switch from the machine, connected 120v into the solenoid pins,push on the plastic tab inside the switch and got a continuity on pins 1 and 4.Reinstalled,pressed start and still no voltage at the inlet valve??Blowed air into pressure hose and heard aair into tub..Any ideas would be appreciated...Frigidaire model gltf2070ds0. Thanks
Nov 03, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire dryer (front loader) and the it keeps flashing 'error' and continuously beeping - The dryness panel has all 4 lights blinking. It's a stackable, so I can't get in the back to try and...
Try and turn off the main circuit breaker to the unit for a couple of minutes.if this does not reset the machine you may need to replace the control board make sure to check and make sure none of the buttons are stuck.
Sep 08, 2010 | Frigidaire Dryers
Apr 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2140ESO front load washer won't start. Not responsive to panel button inputs (Spin Speed, Options). Only reponse is three beeps. When I move the basket back and forth, can hear a little...
Electrolux washer LTF2940ES3 STOP SPINNING -- EVERYTHING SEEMS TO BE IN ORDER, I.E. DRAIN, BELT THE TURNS THE DRUM, ETC. MY GUESS IT'S THE CONTROL BOARD. IF SO, IS THIS A PART I CAN REPLACE MYSELF?
Dec 26, 2008 | Washing Machines
Problem with frigidaire washing machine
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Apr 15, 2007 | Frigidaire GLTF1240A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
147 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
