Question about Cameras
I have a Canon ZR85,when I turn it on the screen is not focus. I tried every thing in the book but no luck. Can you help
  • 4,102 Answers
Hi this problem isnt something you can repair by pressing buttons it seems that the lense has got damged or forced pass its normal place causing the focus problem their isnt nothing you can do yourself as it will require the lense being replaced the problem is you cant get them replaced it just isnt financially worth it as it would cost more than the camera itself.
Unless the lense needs cleaning then their is no setting you can change.
Have you got any warranty left on it if not try giving canon an email or phone call and they might repair it for you just explain the problem and if its a known fault with that model they will replace the camera for you.
Sorry i couldnt give you good news but any camera shop will tell you that unless the camera is worth £1000 or $1750 they just dont repair them or even sell the parts you would need
Posted on Mar 23, 2008
When I look through my lens, the object is totally out of focus no matter what I do. The object looks blurry and color is grayish/brownish. What could be causing this?
You do not say if the pictures you take come out blurred?
I believe this powershot model (depends on the precise model/variant) has an optical adjustment just by the side of the viewfinder (small lever or knob). Try adjusting this to bring your view back into focus.
Check you have not set any special effects on eg soft focus portrait and sepia - probably safer to do a camera reset - see your instruction book.
Good luck
Sep 07, 2010 | Canon PowerShot S1 IS Digital Camera
I cant view the picture clearly while shooting and playback too.i was on a picnic 2wks back,and was taking pictures with my canon SD550 POWERSHOT CAMERA.. all of a sudden the display in the screen blurred...
There is a focuing ring with electromagnets on it, and it swivels to focus. When sand, dirt, lint, or dust works its way into the lens assembly, it can get stuck, failing to focus.
Spray some compressed air into the lens area to try to dislodge it. Then bump it gently if the compressed air doesn't work. Here is a list of things you can try for a jammed lens:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If these don't work, your focus ring is jammed and you will have to fix it or have it serviced. Get an estimate first, since the cost of repair often justifies buying a new camera.
Good luck, these tips might help you.
Aug 27, 2010 | Canon Cameras
Auto focusing not working, Lenses don't rotate at all
i did some research on this problem and one of the things mentioned was that there may be a firmware update to address an autofocus problem with this camera.
Here is a page that may help you get the firmware update.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=17779#DownloadDetailAct
also another thing you may want to do to alleviate this problem is to reset your camera settings to the default setting and try it.
Good Luck
Jun 02, 2009 | Canon EOS 40D Digital Camera
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Lines in the screen
may be ur specific tape got fungus infected , have u tried several DV tapes if the result is same then u have to replace the head of ur camera which is offcourse expensive in service centre get a quote for that
Feb 20, 2009 | Nikon Coolpix 5700 Digital Camera
I have a canon digital video camcorder ntscZR85. Is not that old and used very little now when I turn it on all I get on the screen is multi strips this happen only when I have it in camera mode not in...
Symptoms of your Canon ZR85 shows problem of bad CCD Imager Sensor and this part need to be replaced.
Canon will replace CCD Imager on free of cost basis. Click Canon CCD Advisory to see details.
Good Luck.
Nov 20, 2008 | Cameras
Autofcous and manual focus do not work
excuse me if this is a dumb question but you wouldn't believe the things people do...., but in manual mode are you actually manually trying to move the lens? as manual mode means just that you take hold of the lens and turn it. If it wont turn it sounds like the lens is jammed and needs returning/repairing.
if taking hold of the lens and turning it works for manual mode, take the lens off and clean the gold contacts on both the camera and the lens with a pencil erasor this may bring the auto focus back to life, switch back to auto and try again, if not its most likely the lens but take the body to a canon store and try another lens just to double check the body is ok
drop me a line if i can be of further assistance
best of luck
Jun 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
