Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore compact two-speed washer. Trying to
Kenmore compact two-speed #110 washer. Trying to remove agitator. I removed the lint-fabric softener. I removed a small screw on the side of the agitator.
How do I remove the agitator.
SOURCE: Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Posted on Oct 28, 2006
jsrock516
  • 5911 Answers
SOURCE: Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Posted on Apr 29, 2007
dididsaythat
  • 291 Answers
SOURCE: Maytag SAV365ZAWW Agitator Comes Apart
The should be a bolt that goes thu the center that holds that down with the bottom part of the agiatator.. it might have pulled loose or rounded out the whole for the top part here is a link and a pic http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=3048&modelDesc=WASHER&modelNumber=SAV365ZAWW&documentID=M0512408&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20INNER%20%26%20OUTER%20%28SERIES%2012%29&titleID=00010&
Posted on Sep 20, 2007
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
SOURCE: fabric softener
The softener should not run out as soon as you fill the reservoir.  If too much liquid is added to the reservoir, it will auto siphon into the tub.  Is your washer level front to back and side to side?
Posted on Aug 07, 2008
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
Kenmore 600 series fabric softener dispenser clogged
How do I make the waher Kenmore drop the fabric softener
Aug 25, 2012 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
I have a Kenmore 110. (full number is 110-82984810) It has a "ratchet/screw" type agitator. The big fins on the bottom part agitate back and forth, but the center piece no longer moves in a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082984810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
For future reference you might also want to review / print / save the following Whirl[pool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Dec 26, 2010 | Kenmore Washing Machines
Trying to replace dog agits of kenmore washer, how do I remove upper part of agitator to put in new dogs.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive. (I've used a 1/2" adapter for a 3/8" socket drive)
Jun 04, 2010 | Kenmore Washing Machines
Series 80 Agitator top dosent work
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Following is an illustrated description of the above.
Jan 09, 2010 | Kenmore Washing Machines
Dual action kenmore 70 series washer need to remove agitator
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
74 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
