Question about SanDisk Sansa e250 MP3 Player
Sandisk not compatible with mac computers
My sandisk e250 is not show up on my mac computer. i have used windows media in the past but i just switched computers. What do i do?
  • Tim Kong Apr 21, 2008
    I've had my e370 for over a year, it works great in Windows but not Mac.  Sandisk DOES NOT publish a Mac driver.  It should work in MSC mode independent of the OS (USB storage; instead of MTP), however it does not do either on the Mac.
  • Loteck May 11, 2010
    What Mac OS are you using?
Disregard my last.  I plugged it into my Mac, nothing happened, as usual.  I waited 15 mins or so and it mounted the drive!  I haven't determined if I'll have to wait that long every time.  Again, this is MSC mode (MainMenu/Settings/USBMode).  But now drag-and-drop works just fine.  Also, see freeware "SyncTunes" at http://www.nesfield.co.uk/synctunes/
Posted on Apr 21, 2008
  • 758 Answers
Follow the link below to obtain the driver for your device..Select your device model and operating systemsandisk not compatible with mac computers - 1.gif.....
http://www.sandisk.com/DriverDownload/index.asp
If you are still having problems you can contact myself or sandisk.
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Mar 28, 2008
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
Music file not showing up.Unable to delete music.
Music file problem:
Your music might not be compatable with your MP3 player.
If you are using it with mac and windows.
like you used mac to put the music on but you try to use windows to delete the files.
Mac uses a diffrent file system to windows.
Dec 30, 2009 | SanDisk Sansa e250 MP3 Player
When I go to try and delete songs from my sansa e250, windows media says that there are no songs on the device...however, the device says there are 395 songs on it, and they show up on the device. How do I...
are you trying to delete the songs from a different computer than you put them on ? i had this problem when i used my roomates computer to put some songs on my old sandisc when i tried to erase them from my computer they wouldnt show up but i had no room left on the mp3 so i ended up haveing to erase them on the same computer as i had downloaded them on
Aug 18, 2009 | SanDisk Sansa e250 MP3 Player
"Not enough space for music DB. Please free up 30 MB"
The mp3 manufacturers are often being disingenuous - they plug an mp3 player into a Macintosh, and it shows up, so they say, "Hey! It's Mac-compatilbe!" But, the software is certainly not Mac-compatible, so if you ever experience a problem, there is no way to fix it. Also, the Sansa e200 series does not recognize iTunes format.
In general, I would agree that you need to reformat your player, but I have no idea how to do that on a Mac (I'm good at a lot of things, but I'm Mac-illiterate).
-Tha Mp3 Doctor
Mar 15, 2009 | SanDisk Sansa e250 MP3 Player
How do I delete single songs from a sandisk sansa e250 without deleting all songs on the mp3 player?
If you have a computer or know a friend with one then you can connect to a computer. If you are using the Windows operating system open Windows Media Player. In the library you should see your MP3 player and can click on it and it will show all of your music that you can edit any way you want.
If you are using a USB connection you canjust click on the Sync tab and the edit your music.
Mar 08, 2009 | SanDisk Sansa e250 MP3 Player
Cannot delete the songs on mp3
I do mine through Windows Media Player
1)Plug in Sansa
2)Open up Windows Media Player and wait for the Sansa e250 icon to show up under the library. First time, might say 'What device is this' or 'Autoplay'-for autoplay,you click 'sync media files to Sansa e250 using WIndows Media Player'
3)When library shows, click 'Sync' if it is not already there.
4)Just simply click and drag the songs you want from the computer library to the list pane on the side.
5)Once your done, click 'Sart sync'
TO DELETE
1)Plug in
2)Wait for the icon under Library in WIndows Media Player
3)Go to Songs under Sansa e250
4)Right click desired songs and choose Delete. You only want to delete from Sansa e250-nothing else
~loli~
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
Sylvania SMPK 1021/2021 MP3 Player
have you tried copy and paste or drag and drop.go to your computer and open removable disc or drive or storage device E or F
Nov 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Make a copy of one of the files, and try changing the extension to .mp3.
Apr 18, 2008 | SanDisk Sansa e250 MP3 Player
Apple mac
no, but you can thru windows media player or MY COMPUTER
Apr 17, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
2,039 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
