Question about HP DesignJet 1050c plus InkJet Printer
My 1050C will not boot up anymore. It tells me to check printhead 3 path.
  • 776 Answers
This message is generally received when the belt has worn out or there are few broken teeth on the belt.Look for the drive belt, as if it is not good the cariage will be stuck., also look for the cleaning station me by this go not out of the head so the head is blocked
Please clean and lubricate the rail, and also carefully inspect the path for stray pieces of paper.
Check for little pieces of black rubber under the belt and encoder strip.
I have also seen 2 other fixes: a dirty encoder strip (the plastic strip with little hash marks on it) and a faulty cutter. But most of the time it is the belt
Posted on Apr 26, 2010
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
HP Designjet 1050c begins to plot, then stops plotting with the error message "Turn of printer, check printhead path". What is the problem?
you need to lubricate the slide bar with some thin oil ( sewing machine oil).put the oil on your finger and then touch the bar this way you wont spil oil into the printer
Nov 03, 2009 | HP DesignJet 1050c InkJet Printer
Switch power off check printhead path(2)
Could be worn ink tube system and printhead cable snagging when the carriage moves, or dirty carriage support bar
Oct 12, 2009 | HP DesignJet 1050c InkJet Printer
Check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Jun 05, 2009 | HP DesignJet 1050c plus InkJet Printer
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check issue
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check printhead path Type 1
May 20, 2009 | HP DesignJet 1050c InkJet Printer
Switch power off check printhead (1)
Good morning. The CHECK PRINT HEAD PATH error is caused by the sensors on the print head carriage sending signals to the electronics that the carriage speed is incorrect. Generally, this is a mechanical problem caused by an obstruction, such as a paper jam or some other item in the paper path. However, the most common reason for the error is a worn out carriage belt. Look under the belt to see if there is debris resembling pencil erasure crumbs. If the crumbs are present, your belt is disintegrating and needs to be replaced. The parts can be purchased at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 22, 2009 | HP DesignJet 1050c InkJet Printer
Printhead
When the plotter goes through its initialization, it stops, the printheads move to the right side and the window displays "switch power off, check printhead path (2)" I've turned the power of an wiped things down, I've unplugged and then restarted but continue to get this message. What do I need to look for or do to get it back on track?
Oct 17, 2007 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
