Question about LG Refrigerators
My LG refrigerator (LRSC269944TT)is leaking water from the door where the supply tube goes in near the bottom henge. When I push the lever to dispense water it takes a second or two for the line to fill up again. I have removed the door and looked into the channel that the tube goes into, and it all looks connected well. I have taken apart as far as I can on the dispenser area and all seems correct there. Please let me know if this can be repaired and how. Thanks, Kevin
watugot
  • 290 Answers
SOURCE: Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Posted on Oct 20, 2007
  • 1314 Answers
SOURCE: water dispenser lever on Frigidaire
you can get the part at any appliance parts store just make sure you have the correct and complete mod number off the serial plate in the fridge compartment if i reamber right there are two slots at the bottom of the cover like little rectangles that a screw driver fits into and you gently pry it out then unplug any wires to the keypad set it down and can see the rest from there
Posted on Dec 31, 2007
dcp2
  • 63 Answers
SOURCE: Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Posted on Jan 28, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Posted on Nov 09, 2008
Water dispenser leaks out bottom of door when I dispense water.
Sounds like a small hole in the plastic water tube inside the door. It is a replaceable part but you may need to remove the freezer door to do that. The old tube should come out the bottom near the hinge area. The new tube is then pushed up inside the same hole. There is usually a plastic conduit in the door for the plastic tube to follow. Here is the part number I found for the new plastic tube.
W10277960 about $42 to $45 depending on part store.
Apr 30, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
No water
It is fairly common for the water tube in the door to freeze. Remove the front grill at the bottom of the refrigerator, find the water disconnect to the door and disconnect one side of the tube. Most newer connectors just have a little ring that you push in and this releases the tube. Push the water dispenser lever for just a second and see if water comes out the tube. If it does then the tubing in the door is frozen. You will have to shut off the refrigerator off for a while and leave the door open so the tube can defrost. Push the tube back into the connector under the refrigerator and wait. after an hour or two water should come out the dispenser. Another possibility id this doesn't work is the water tank is frozen in the fresh food section behind the crisper. Again you will have to shut off the refrigerator and let things thaw out.
Aug 02, 2014 | GE GSL25JFXLB (250 cu ft) Side by Side...
GE Refrigerator Model GSH22SGRBSS NO WATER TO THE FRONT DOOR DISPENSER. ICE OK
Generally, the path to the water dispenser is as follows: water comes in from the wall, goes through a solenoid (valve), and through some tubing to a reservoir behind the fruit and vegetable compartments. From that reservoir, more tubing goes down under the refrigerator, then up near the bottom of the door hinge of the door that has the water dispenser.
First, listen for if there is a water running sound when you try to use the water dispenser. If there is not, then most likely there is no water coming from the supply at the wall, or the main solenoid where the water comes in is not working. If ice is being dispensed, you know that the switch that you press with your cup is good, but that doesn't mean that water is coming in to make new ice. It could be just existing ice being dispensed.
If you DO hear a water running sound, then something is leaking, possibly onto your floor. Follow the path of the water in the first paragraph to locate the leak. Could be that some tubing came off, or burst.
Nov 08, 2011 | GE Monogram Side by Side Refrigerator
Hi, I just found a leak in the back of the fridge from the green water line. Is it something I can fix easily or should I have an expert take a look?
If water appears to be leaking from the back of the refrigerator, check that the water line from the household water supply to the refrigerator is not damaged or cracked. Check all connections that are accessible such as the connection at the supply valve and the connection point of the supply tubing onto the back of the refrigerator. Check that the tubing is firmly inserted into all fittings and all fittings are tightened.
Saddle Valve Shutoff Valve
Leaking from under the door
On exterior dispenser models, if water appears to be leaking from under the refrigerator door, look and feel under the door to ensure the water connection to the dispenser is properly done. Firmly push the water tubes into the fitting.
NOTE: This connection was disconnected if the doors were removed during installation or if the door swing was reversed.
Leaking at the filter
Ensure that the filter is correctly installed.
Jul 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Tubes on the bottom of the refrigerator connected to water dispenser leaking every time I dispense water..help
The water valve for the dispenser is electric controlled and in the rear of the machine. Which is why there is no leak while it is off. There is a push in connector which can be purchased at most hardware stores that is most likely either cracked, or simply not connected tight which is why there is a leak when the water dispenser is turned on. Check that union. should be near the bottom door hinge. It is there so the door can be removed if necessary.
Mar 13, 2010 | Refrigerators
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Take off freezer door
Why don't you just take off the handles? That is what we did and it worked just fine.
Oct 07, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
32 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
