Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Why is my garbage disposal leaking at the red dot on the bottom?
  • 5,568 Answers
The 'red dot' is likely the reset button for the circuit breaker and if water has gotten past the shaft seals of the motor, it may present an electrical (shock) hazard unless that circuit is protected by a 'ground fault interrupter.' Since repair of these will cost more than replacement, I think yours is due.
Posted on Apr 26, 2010
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Posted on Sep 23, 2010
KMusselmann
  • 247 Answers
SOURCE: garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
Posted on Mar 23, 2009
  • 63 Answers
SOURCE: I have a small leak coming from the bottom of my garbage disposal
replace unit...period
Posted on Apr 06, 2009
How to fix a leak from a garbage disposal?
Check location of leak. If from bottom, replace disposal
Copy following link to repair, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
Aug 18, 2012 | KitchenAid Batch Feed Garbage Disposal...
Tip
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
on Sep 23, 2010 | Kitchen Appliances - Others
The in sink erator model # 5-81A is leaking from the reset (red) button underneath. Help???
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
heatman101
Oct 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Disposal is leaking at bottom out of the body... No leaks in plumbing or outside of the body
heatman101
Aug 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
It Leaks.
heatman101
May 08, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking from bottom of disposal where
heatman101
t
Feb 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking out of bottom of unit, near reset
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
2,549 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
