Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Weed eater starts fine runs a few minutes and then dies when you try to press the trigger
    Problem Solver:
  • 18 Answers
That is a great solution mrfixit-jerr, just wanted to add that if you need any of those parts, out of all the places online or locally Ive always used ereplacementparts.com for tool parts on my equipment. I recently had to get a small carburetor and the replacement worked great!
Posted on May 12, 2010
Weed eater runs fine till I tilt it down to start trimming then it dies??
Check the gas line that is in the fuel tank . It has a filter on it and if its not down at the bottom of the tank where it should be then its not getting the gas it needs. If you tip it the gas may be too low for the hose to pick up. The hose needs to be on the bottom.
Jul 14, 2016 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Murray weed eater won't stay running
have to go further in the carb, If you left 'todays' ethanol gas in the weed eater for more then a few months, it probably messed up the Carb. Ethanol gas is very bad for carburators on any machine
Aug 31, 2015 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Husqvarna weed eater starts , but blows alot of smoke & then stalls out
    Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    String Trimmer Starts Then Stalls
    My String Trimmer Starts But Won Stay Running
    Craftsman Trimmer starts then dies
    How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
    How to Clean Two Cycle Two Stroke Engine Carburetor
    Sep 06, 2012 | Husqvarna 128 LD Weedeater
    Bought new poulan pro PP125e weed-eater and it has an accelration problem. Manual says may need carburator adjustment. Do you know how to adjust?
    new --under warranty -- take it in for a warranty service and adjustment
    they will know how to adjust it as well as will have the correct tools for the job
    Jul 26, 2017 | Garden
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Poulan Pro weed eater won't accelerate.
    check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
    Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Weed eater starts, runs 5 min. then cuts off
    The gas cap may be clogged.
    The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
    You may also check the air breather, it may be dirty as well.
    Just let me know if you need further assistance.
    Jim
    Jun 28, 2009 | Poulan Pe550 Gas Edger
    Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
    The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
    May 17, 2009 | Craftsman 25cc Gas Line Trimmer
    Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
    1,588 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
