Question about Kohler K-10416-BN Fort½ Single Control Kitchen Faucet with Side Spray...
I can't seem to find the o-rings for this faucet. Can anyone tell me where I can purchase them?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
Go and call kohler direct and they will ship them to you.
Posted on Apr 27, 2010
Faucet won't stop dripping
you can fix it yourself by replacing the o-rings in the cartridges inside the handles. if its washers, replace those and the seats located inside the faucet handles. depending on how old your faucet is, the replacement parts may be more than if you replace the entire faucet.
Nov 15, 2013 | Home
We purchased a 16927 Series SSSD 5 years ago. the faucet doesn't swivel on the base, so the nut securing the faucet to the sink continues to loosen under the sink. I've tried lubrication, I've...
There is a possibility of corrosion between swivel and base. Remove faucet and take to a work table and try and twist swivel spout off. I t may be tight, but the unit is not satisfactory and may need replacement. I have repaired such faucets before and many have been cheaper to replace. There a o rings between spout and body if you get it apart check mating surfaces any erosion discard unit. If OK replace o rings and use silicon grease. No petroleum products as this will cause o rings to swell. Good Luck
Nov 16, 2017 | Plumbing
We do not have book on the kitchen faucet which was purchased by a previous owner. Looks just like the Danze D306357BN. It is leaking from the first joint above the base. A plumber could only tell us that...
there are several O-rings inside the spout assembly. 3 that I know of from memory.<br /> <br /> here is a link to the PDF parts breakdown to show your plumber. also that faucet is for the bathroom sink.<br /> <a href="http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN">http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN</a><br /> the link to the PDF is at the bottom of the page "illistrated parts list" <br /> <br /> here is the link to the kitchen faucet. just click on the "illistrated parts list" to get the breakdown.<br /> <a href="http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357">http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357</a><br /> <br /> if neither one of these is your faucet, just continue looking through till you find yours, and call a different plumber.<br /> <br /> hope that helps<br />
Aug 31, 2010 | Danze Plumbing
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Leaking kitchen faucet
the swivel on any tap has an "O" ring or seal at either side of the outlet into the arm
Any leaks from this area indicate a ring/seal failure
Jan 16, 2018 | Kohler K-10416-BN Fort½ Single Control...
It seems like the rings expanded or something. No
I got old pullout srayer out bought a universal one and it will not go through. What part number do I need. Can I buy that piece.
Dec 21, 2009 | American Standard Kitchen Faucet 6310 020...
533-50 kitchen faucet leaks above base mount at pivot body when water is on and the faucet is pivoting to fill other sink.It dribbles out on counter top.Seems not to leak if faucet stays stationary.The...
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Sep 27, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Feb 12, 2009 | Blanco Classic Single Handle Faucet with...
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Kohler K-10416-BN  Fort½ Single Control Kitchen Faucet with Side Spray... Logo
171 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
