Question about Linksys WRT160N Wireless Router
Error 321 Getting 321 error - erthernet cable not connected
  • 550 Answers
Are you trying to connect a computer to the network or it is another wireless device.
For this you don't need to use Linksys Easy link advisor.
All you need to do is, open the router set up page and check the settings of the router.
according to the settings on the router, you can connect the new device to the network.
is ther any computer connected to the router?
use that cmputer to open the router set up page.
Posted on Apr 26, 2010
What is the problem and solution to error code 420 or 321
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
May 15, 2014 | HP OfficeJet D135 All-In-One InkJet...
Error 321
You get this error when you try to install the router using the CD.
This error shows that your computer is not connected to the router or the connection between the router and the computer is not working. When you run the CD , it will ask you to connect the computer and the modem to the router with the cable. You will see all the lights lit up on the router according to the instructions but still you will get error 321.
In this case you will need to check the firewall settings of the computer. If there is any firewall installed on the computer, then turn it OFF. Make sure that the Local area connection on the computer is not Disabled. The local area connection should not have any static IP address assigned. If there is any then set the IP address to automatic.
Try to run the CD again and see if that works. If that doesn't work then try to setup your router without the CD. You can setup your router manually.
from http://fixhomenetwork.com/blog/error-321-router-setup/
For help in setting up router without the cd go to:
http://fixhomenetwork.com/router-set-up.php
May 18, 2011 | Linksys WRT120N Router
I keep getting an error message when i set my router up
The LAN cable maybe faulty, try a different LAN cable.
Jan 04, 2010 | Linksys WRT120N Router
Everytime i set up my router it says "your ethernet cable does not appear to be connected properly. Error 321: Ethernet Cable not connected" now i have tried setting this up multiple times but i keep...
there is a program on your computer that shouldnt be there thats preventing it from working..go to start then control panel then clink on maintenance+system then click on device manager and any program in the list in yellow triangles you uninstall.
Linksys WRT160N will not finish installing. On the 4th step it says your ethernet cable does not appear to be connected properly. Error 321. I don't really think its the ethernet cables because i tried 2...
error 321 or 322shows that the cable is not connected to the router and the computer.
That is actually a bug in the CD. Even if the cable is connected it shows that it is not connected.
You can set up the router manually, without the CD.
Click Here for step by step solution
Nov 03, 2009 | Linksys WRT160N Wireless Router
321 error
try this power of both pc and router , unplug router power on pc then power on router see if it then picks up the isp, if not just simply unpup router and plug it back in while pc is running hope this helps!!!! good luck
Mar 23, 2009 | Linksys WRT54G2 Wireless Router
KEEP GETTING ERROR 321 WHEN SETTING UP LINKSYS WRT54GS ROUTER
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 17, 2009 | Linksys Wireless-G Broadband Router
Still not connected
vhevk your ethernet cable wire.
if u connect router to swithc then use straight cable.
if u use router to computer use cross cable.
Jan 10, 2009 | Linksys Wireless-G Broadband Router
Linksys WRT160N Wireless Router  Logo
257 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
