Question about Whirlwind FH-778 Air Conditioner
My home A/C is blowing hot air when the thermostat is set on cool. Every now and then it will switch back to cool but not for long. How can I fix this?
Sounds like a bad thermostat. First test it by making a "jumper" cable. 2 alligator clips connected by a wire.(wear rubber gloves to prevent shock) Remove the cover to expose the wiring. Touch one end to the R- RED terminal and the other to the Y-YELLOW terminal. Your A/C should kick on. If your A/C works the thermostat is the problem. Buy another at the hardware store. BEFORE you replace it cut power from the breaker box. (Keep the gloves on just in case.) Their are 4 terminals on the thermostat with color coded wires attached. R-Red, W-White, Y-Yellow, G-Green. Mount the new thermostat replace wires and restore power. If this solves your problem great; If not call a HVAC tech. Good Luck
Posted on Apr 27, 2010
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Armstrong Ultra SX 80 Central Unit won't kick off heat setting
From what you describe it sounds like it might be a relay problem.
It needs to be diagnosed properly first.
Apr 21, 2017 | Heating & Cooling
Furnance not heating
Make sure that the thermostat is set for the proper medium that you are using being gas or electric. Inside the cover of the thermostat should be a setting for either eletrical heat or gas heat. Set this switch for what your system is G for gas or E for eletric. This may solve your problem. Good Luck hope this helped you some
Dave
Oct 26, 2009 | Intertherm P3RA-036K Air Conditioner
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
97 Ford Econoline air conditioning and vent settings blowing hot
I know from experience that if the coolant is to low ( not just the freon levels in the compresor but the antifreeze/coolant level as well) the AC system will not cool and will blow hot. Check the coolant Antifreeze and freon levels, even with the Coolant being a little low my 1998 Ford E150 Van will blow hot. After you have ruled out of these possibilities and the chance it is the thermostat most likely the problem is what Ford calls the "Flap" it controls the air flow through the vent system when you switch from Heat to AC. When the Flap is working it closes off one systems air flow so as to not interfere with the current climate selection.
Feb 21, 2009 | 1997 Ford Econoline
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
A/c and heater
Is it leaking antefreeze?
The thermostat might be gone or needs a bigger thermostat
It could be a vaccum leak for the drivers side blowing cool air and the passenger side blowing warm air
Does it have dual air control switches one for drivers side and one for passengers side?
Oct 28, 2008 | 2003 Pontiac Grand Prix
Whirlpool air conditioner - 8000 BTU - window unit
Your parents must be proud of you! You must have a big red "S" upon your chest!
Aug 22, 2008 | Whirlpool Heating & Cooling
Heating & Cooling Logo
355 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
