Question about Char-Broil Quickset Traditional 463761006 Grill
How to install the propane tank
How do i put it on because i donbtthink its supposed to be bent
    Guru:
  • 1,051 Answers
Your correct, the tank should either srand upright in a tank holder or hang from a device buit onto the grill. If you need to improvise, using some paving stones or whatever just make sure you don't pull the gas line.
Posted on May 04, 2010
Can you get water in LP lines when filling RV w/ propane? Frig quit on propane,worked on electric. Had filled w/ propane two days earlier. mechanic found oily water in line; range still worked.
Yes water can do compensation build up in your propane tank. Some tanks have a drain pit on bottom reclaim propane and open the pit. If your does reclaim the propane and drain tank. If not reclaim propane and remove tank then remove filler valve turn tank over drain access water leave tank up side down over night. Put fill valve back on and mount tank. After lines are back on turn stove on leave on for 48 hours. Turn valves off and refill tank. Best of luck.
Jun 10, 2016 | RVs
Asdv-6sr won't light....just bought the trailer and have read the manual. This model is supposed to light itself and won't. The on off switch inside will not show any light at all and almost seems that...
It sounds like the spark isn't working. Is there a clicking sound when you try to start it? The propane may not be connected. I think there is a knob on the tank and on the grill as well.
Elisa Jed ' http://www.gravespropane.com/services.html
May 19, 2014 | Grilling
I have a 40000 btu all pro and it lights but the line freezes up and it starts throwing a large flame out, what is going on ?
Sounds like the regulator is bad or the tank is overfilled. The liquid propane is supposed to vaporize under high pressure within the tank, and the regulator lowers the pressure to feed the burner. It seems that your regulator is getting liquid and it is vaporizing at low pressure in the regulator. When the liquid vaporizes at low pressure it gets super cold.
Jan 26, 2014 | All-Pro Propane Garage Shop Heaters - All...
I have 3 natural gas fire places. i would like to know if i can change it to propane. i'm thinking i would just have to change the logs and hook a tank up outside. can some tell me if this would work.
Typically gas log sets are factory made for either natural gas or propane. If you want to use them on propane you need to find out if a LP conversion kit is available for your brand/model #. Ask the place where you bought them or ask the company that installed them (if you didn't put them in yourself). If they can be changed over to propane, then you will need to buy the propane tanks, regulator and gasline or just have your local propane company put in a pair of 100# cylinders for each fireplace (or 420# cylinder to service all 3 fireplaces) with an auto-switchover regulator. They can also do the conversion, if the conversion kits are available. Let me now if you have any other questions. Douglas
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
Gas gauge... how does it work... or is it supposed to be hooked up to the can somehow??
If it's like mine, you literally hang the propane tank on a hook. The gauge is basically a spring and as the propane is used and lightens the tank, the spring contracts.
Jul 27, 2010 | Weber Genesis E-320 Propane Grill
Flame is low when turned on highest setting
There are a few causes for that.
1. You are low on propane.
2. Your propane tank is overfilled, and the overfill protection device is restricting gas flow.
3. You have turned off your grill using the propane tank instead of the control valves on the grill. This may also cause the overfill protection device to engage. You can reset this by turning off your control valves on the grill, turn off the propane tank, unscrew the hose from the propane tank, then put the hose back on securely, turn on the propane tank and turn on the control valves.
4. Your burners are very rusty and may be clogged. Clean or replace the burners.
Mar 03, 2010 | Sunbeam Grilling
The metal tube that connects the propane tank to the unit snapped ON but now won t come off
It has "Ears" on it to prevent it from coming off...to get it off requires pushing in the ears and then sliding it off simultaneously. But then the ears will not snap good into the burner any more...Its meant to stay in after its assembled and just the propane tank is supposed to unscrew and come off. However the tube should still spin to prop the tank in either side for your convenience. its safe to remove and re-install the tank as often as you like.
Its not going to "Spill" but just give a split second "FFFTTT" sound as it is removed.
I hope this helps you out with this...
8-) post comments if you have anymore questions with this. i check on them from time to time.
Jun 07, 2009 | Coleman Propane Grillin Griddle 9931-750
Pro Com QD250T can I install directly to a 4 gal. Propane tank
You should not have the Tank in the house , it's like storing a bomb in the house . for more info call 1-866-886-5989
Nov 17, 2008 | Procom ML300HGA Heater
How to use propane tank?
leave the propane tank on and install a gas ball valve after the tank. you can see that the gas is on by the position of the valve,
Aug 16, 2008 | King Kooker Grilling
Jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Jan 21, 2008 | Grilling
Char-Broil Quickset Traditional 463761006 Grill Logo
425 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
