Question about Garmin Forerunner 101 GPS Receiver
The unit will not show distance in miles even when in bike mode. Main screen shows distance in feet even in bike mode. When I go back to check which mode the unit is in it says bike mode. As I have done this at least a dozen times. Lots of resets, battery removal the manual must be missing a step. Thank you.
  • 508 Answers
Not sure about this but from the little bit that i read, it is not designed for that, seems to be a training tool of some sort. You might have already done this but here is the link that i followed. Maybe something in there or the pdf file will help you out, but i actually have not much of an idea on this one. So here you go
http://www8.garmin.com/products/forerunner101/spec.html
Hope this helps
Posted on Apr 27, 2010
Does distance show kilometers or miles?
On a digital display the default in U.S. is miles. Refer to your owner's manual or call dealer if you need to change it. A km is .6 of a mile, so just drive about 10 blocks (around a mile). If the odometer registers around 1 unit more it's probably miles, if it says close to 2 then it's probably km.
May 08, 2016 | Cars & Trucks
How to write this problem in code
const feet_per_mile = 5280
distance = 8.5
print "the distance is "+distance "+miles or+" distance*feet_per_mile+" feet."
Jul 14, 2014 | Computers & Internet
How to convert from feet and inches to metric?
Click the screen to access main menu this should bring up the ability to click change preferences and then in that menu you should be able to scroll through and find the option to change from feet and inches to metric.
Mar 02, 2011 | Tomtom GO 750 LIVE GPS Receiver
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    The distance for the trip in my favorite is wrong.
    Sounds like you might have "off road" selected for your navigation preference. Shortest distance between 2 points is a straight line, or great circle for GPS units. As the crow flies will be shorter than a road route.
    Jul 04, 2010 | Garmin nuvi 205W GPS Receiver
    My garmin nuvi 780 shows me at an address a good half mile down road from my house. Also, the lat and longitude it shows me at while i'm home is 15 miles from where i am. whats wrong here and how do we fix...
    The accuracy of any GPS device depends upon having good locks on multiple GPS satellites (at least 4, but up to 12 on many units).
    The main screen on the nuvi shows the acquisition quality in bars (like a cell phone), but provides no further information. If you have 5 bars, your accuracy should be much better than what you report. Ideally, it should be as good as 4 meters (13 feet), though that will vary depending upon the current configuration of GPS satellites overhead.
    An error of 15 miles should never occur. How confident are you of your actual latitude/longitude?
    Jan 17, 2010 | Garmin nuvi 780 GPS
    TR SR706 purchased 6 months ago. Unit powers on to
    Onkyo USA Corporation
    18 Park Way
    Upper Saddle River, New Jersey 07458
    For Dealer, Service, Order and all other Business Inquiries:
    Tel: 201-785-2600
    Fax: 201-785-2650
    Hours:
    M-F 9am-5pm ET
    For Product Support Team Only:
    1-800-229-1687
    Hours:
    M-F 9am-8pm | Sat-Sun 10am-4pm ET
    Regional Service Center Dtr Technologies
    2525 West 6th Aven
    Denver, CO 80204
    303-573-6288 (Tel)
    Distance: 960.0 miles
    show map
    Please see below for local Service Centers.
    Media Associates Inc.
    612 National Ave.
    Mountianview, CA 94043
    650-968-2444 (Tel)
    Distance: 33.6 miles
    show map
    http://www.onkyousa.com/loc_results.cfm
    Oct 04, 2009 | Onkyo TX-SR501 Receiver
    How do I change my garmin forerunner 205 from miles to kilometers
    To change this setting go to the menu on the Forerunner by pressing the Mode button then follow the steps below:
    1. Select Settings
    2. Select General
    3. Select Units
    4. Select Distance and/or Elevation and change this to Metric if you wish to see the measurement units in kilometres and metres, select Statute if you wish to see units in miles and feet
    Jun 21, 2009 | Garmin Forerunner 305 GPS Receiver
    Navman iCN 520
    This may be because you are in Simulation mode. To leave this mode:
    • Go to Main Menu > Settings > Routing > Next Page > Next Page
    • Now un-tick all of the options you see on the screen
    • save
    Sep 21, 2008 | Navman ICN510 GPS Receiver
    Garmin Forerunner 101 GPS Receiver Logo
    75 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    Steve
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
