Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
No picture...check signal cable Analog message following movement and re-connection
  • Samsung Master
  • 1,684 Answers
Check for bent pins in the signal cable. Unplug the cable from the back of the computer and look at the end, you will see small pins sticking out. We have seen many times when people move systems that a pin will get bent over and when you plug it in to the PC it gets flattened out all the way. If you find a bent pin you may be able to straighten it out with a pair of needle nose pliers but if it breaks you can get a replacement cable for $6.50 shipped, http://www.ccl-la.com/catalog/product_info.php?products_id=54
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on May 01, 2010
Hello ,I just purchased an Asus desktop but I keep getting the message on my monitor,No Signal.Can someone help? Do I need to insert the video card first? No luck with configuring UEFI BIOS either.
Where is the monitor connected to the computer? Is it an analog or digital cable? Look on the monitor setup screen and see if changing the input signal will get you a picture. You're kidding about the video card, right? If the video card is in your hand and there is no place to connect the monitor cable....... duh.
Sep 26, 2015 | ASUS Essentio Computers & Internet
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
No picture
On your remote, there is an "Input" button. Press this a few times. Your TV as a few different inputs (connections for cable boxes, VCRs, and DVDs). Each time your press the Input button, your TV will switch to the next one. After a few presses, you will find the signal from your cable box. I hope this was helpful, best wishes.
Mar 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
No signal
You don't specify what kind of monitor, CRT, LCD, or even a TV attached to your system, you're using. It's likely the monitor is set to receive a certain kind of signal (either analog or digital) but it's receiving the other one instead. Before proceeding to the next steps, ensure the connections are solid and the the screws are set tightly and there's no movement.
Get your user's manual and learn how to navigate the monitor's menu in order to get to the setting where you choose Analog (for a VGA cable connection) or more commonly with LCD screens, Digital (DVI).
VGA and DVI connectors differ in shape and in the number and layout of their pins. If you're using a video card with a DVI connector (larger, more squarish D shape, with three separate sections of pins) then your monitor shoud be set to Digital. Else, your connector is VGA and thus your monitor should be set to Analog.
If both are in synch and you still do not get a signal, it's possible the video card has given out its ghost, since if you DO see the NO SIGNAL message displayed on your monitor, the monitor is Ok.
Aug 17, 2009 | ViewSonic Computers & Internet
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
111 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
