Question about Hansgrohe 06358620 Pressure Balance Valve w/ Scroll Handle Oil Rub Bronze
Hansgrohe 06358620 shower not hot enough
I just had a new Hansgrohe 06358620 shower installed. The temperature of the shower is lukewarm and I would like to adjust the temperature to allow a hotter temperature. How do I adjust the shower control? Thank you!
  • 299 Answers
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Posted on Apr 28, 2010
Testimonial: "Thank you so much for your help! Will try it out - your instructions are clear and sound do-able! "
BRAND NEW RINNAI BOILER E75cn Shower runs hot then warm then hot then lukewarm then cool then lukewarm then cold
get the installer people back to set the operation correctly as it should have been test run before they left
read your operators manual for settings or trouble shooting
Feb 24, 2016 | Home
Shower takes too long to get hot then runs lukewarm then hot lukewarm then gets cooler & and cooler &cold
There is a temperature adjustment on the hot water tank.
Perhaps it is set too low. They are often red in color.
Feb 24, 2016 | Home
Clubmaster shower not holding temperature. Hot water not coming through.
There's only there things that are clubmaster, a shower head, and two hand held sprayers.
They all spray water, they don't heat water.
Did someone install a new part, the one that's behind the wall ?
If they did, most have a safety so people don't get burnt and they need to be adjusted.
Apr 16, 2013 | Hansgrohe Clubmaster Showerhead, Steel
Adjust hot water on hansgrohe metro shower
The hand shower and wall bar does not control temp. The valve in the wall would control the temperature of the water going to the shower. I would need to be able to identify the model number of the valve in the wall to be able to give accurate instructions on temperature adjustment. If you need help identifying this valve feel free to give me a call at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough
Oct 13, 2012 | Hansgrohe 06496 Croma Hand Held Shower -...
Hansgrohe shower not hot enough
The first thing to do is identify the unit so I can give accurate instructions. Hansgrohe makes many valves and the temperature adjustment between them is different. Feel free to call me at Hansgrohe at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'd be happy to help identify the unit and get you the instructions for the temperture adjustment.
Oct 05, 2012 | Hansgrohe Home
Hansgrohe shower thermostat: water is getting only Lukewarm. Hot water ok in sink and throughout rest of house.
The first thing to try is cleaning the filter screens on the thermostatic cartridge. Hansgrohe thermostat valves have filter screens to protect the element from debris or water deposits. If they begin to get clogged the valve will have a hard time regulating temperature.
Jul 28, 2012 | Home
How to adjust water pressure
To adjust the pressure on this type of valve you simply rotate the handle counter clockwise from the off position. As you rotate the handle it will increase the volume as you increase the temperature. Feel free to contact me at Hansgrohe. David Scarborough 1-800-334-0455.
May 06, 2012 | Hansgrohe 06358620 Pressure Balance Valve...
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
No hot water
Sounds like the temperature limit stop in the control needs adjusted
May 24, 2009 | Home
Hansgrohe shower
it's possible sometimes you can get brand new junk. one question is the thermo coupler in the right postion? i would check to make sure that it is indeed picking up the temp like it should.
Sep 02, 2008 | Home
Hansgrohe 06358620 Pressure Balance Valve w/ Scroll Handle Oil Rub Bronze Logo
2,940 people viewed this question
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
