Question about GE GSD5320DBB Dishwasher
GE Profile dishwasher model GSD5320DBB is leaking profusely under the door
  • GE Master
  • 12,061 Answers
Motor and pump assembly leaks.
If you see water leaking out where the plastic body and metal motor part comes together, sometimes replacing the impellor and seal kit will fix you up. If you see water leaking out of the drain valve stem, usually best to replace the motor and pump assembly.
Sometimes the pump connector ( above the motor and pump assembly ) will get a pin hole in it and the waterdribbles off of the motor and pump assembly.
http://www.ehow.com/how_112279_fix-leaky-dishwasher.html
Leaks under the Door
Leaks under the door can stem from a variety of causes. If your dishwasher is very old, the tub itself may have become corroded and may have holes. Inspect your tub; if you see such damage, use an epoxy patch kit to repair it, following the kit’s directions. Another possibility is that your dishwasher is not level; this can cause leakage. Open your dishwasher and place a carpenter’s level on the floor of the dishwasher or on its door. If you find that the dishwasher is not level, you may be able to fix the problem by adjusting the feet, found along the front of the dishwasher, perhaps behind a toeplate.
If you have not yet found the problem, the next step is looking inside the dishwasher. Again, disconnect power to the dishwasher before getting started. Remove the front panel located below the door; this may be held on with screws or with hooks. Your goal down here is to find what is leaking so that you can either adjust or replace it. You will see a drain hose, about an inch and a half across, which connects from the dishwasher pump to the drain of your kitchensink. At either end, it is held in place with a clamp. Check these clamps; if they are loose, use a screwdriver to tighten them. Check the hose itself for any signs of leakage; if the hose appears to be damaged and leaking, replace it. There is a second hose, the recirculation hose, also attached to the pump. Inspect the fitting and tighten if necessary, and inspect the hose itself.
Check the hoses on either side of the water inlet valve to make sure that they are securely connected, and that they are not damaged. Tighten any loose clamps.
The next and last items to check are the gaskets for the heating element, and the seal for the pump. If the gaskets are loose, tighten them; if they are obviously worn or damaged, replace them. If you have checked everything else, the pump seal may have deteriorated. If this is the case, contact a repair professional for replacement.
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
http://www.applianceaid.com/
Posted on Apr 26, 2010
My door is locked on my dishwasher and will not open?
You will have to pull the unit out from under the counter and you need to remove the screws that hold the hinges on the bottom of the door in order to remove the door to service it.
Apr 02, 2015 | GE 24 in. Profile PDW7800 Built-in...
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Ge profile leaking by the left corner of machine
check the door gasket on the lower left there is a rubber gasket that may have come out of place.
Oct 23, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge profile build in dishwasher model #PDW9880J03SS is leaking
open the door look up 4 two screws , remove them and pull the unit out
Jun 18, 2009 | Dishwashers
My ge profile dishwasher oveheated.
There was a recall on some GE dishwashers, but yours was purchased a bit before those affected. Just to be sure, go to http://www.geappliances.com/products/recall/dw07/ and input your full model and serial number (including the last letter of the serial number). Of the models affected by the recall, I've personally seen (and have photos of) one that burned, plus one that was close to it. Recalled ones can be updated for free, or if you decide to replace, qualify for a rebate toward a new GE dishwasher. (the recalled ones had problems with the wiring inside the door) If your model is not one affected by the recall, I would contact GE customer relations via their answer center phone (800-626-2005) to report this potential safety issue.
Feb 01, 2009 | GE Profile PDW9880NSS Stainless Steel...
I have ge monogram dishwasher (zb6400) that leaks at the handle
I've had problems with leaking dishwashers before and it has usually turned out to be the gasket around the door. You might try replacing it - it's usually easy enough to do yourself - and see if that fixes your leak.
Jan 02, 2009 | GE Profile PDW9880NSS Stainless Steel...
GE GSD5320DBB Dishwasher Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
