Acer DC Power Jack
How to remove the DC Power Jack in my Acer TrevelMate 6460
  • fffjguzman Mar 23, 2008
    What is Desolder?
    Genius:
  • 3,587 Answers
Well..actually, it's installed on the motherboard..you'd need to strip the whole unit open, and then figure out how to desolder it from both top and bottom layers of the board..loads of potential issues arise on that.
Posted on Mar 23, 2008
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
DC jack for aspire 8943g
Just go to any electronic shop and bring the sample jack, surely they have one for you.
Hope that helps!
Nov 23, 2011 | Acer Aspire Ethos 8943G-5464G50Bnss...
I have an Acer Aspire One and when I plug the charger in I have to spin it or wiggle it or both to get the battery to charge. Once I have it in position it generally stays on charge, but if the cable is...
It could be either one Sarah.
The AC adapter's (Charger) cable, or the DC Power Jack where the AC adapter plugs into the laptop.
This is an example of the DC Power Jack not installed,
http://www.laptopjacks.com/view_part/Acer-Aspire-ONE-AOA150-ZG5-DC-Power-Jack-AC351816.html
(You can click on the three views of the jack to enlarge)
1) Check the DC Power Jack to see if it's in good repair.
Battery removed use a small flat tipped screwdriver, and Gently see if you can move the Center Pin around in the jack.
See if the Center Pin will move side to side a small amount. There is supposed to be No perceptible movement.
Referring back to the closeup photos of the DC Power Jack, the flat blade-like prongs are upside down, in relation to how the jack sits on the motherboard.
The flat prongs go down through the motherboard, and are soldered to the motherboard.
If the center pin of the jack is stationary, but the jack as a unit moves around, one or more solder joints, (Connections) for the flat prongs may be cracked.
The repair consists of completely disassembling the laptop, removing the broken DC Power Jack, and installing a new one.
Acer Aspire One service manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
(Click on the blue - One - in Aspire One.
This is a PDF file. The computer you are using now has Adobe Reader on it which uses PDF files.
After you click on the file name (One) it may take up to 30 seconds before you see the first page.
It may also take additional time for the file to fully download.
(Took 12 seconds just now for full download)
No perceptible movement of the DC Power Jack? Suspect the cable of the AC adapter right near it's plug. (Plug that plugs into the DC Power Jack)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 25, 2011 | Computers & Internet
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 08, 2010 | Acer Aspire 3680 Laptop
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
How do I replace the DC power Jack socket on my ACER Extensa 5620 .Mosel NO MS2205
Here is a place to buy a dc jack for the motherboard:
http://www.buy.com/prod/ac-dc-jack-power-port-connector-socket-for-acer-extensa-5220-5420-5620/q/sellerid/23962916/loc/101/215782024.html
This video will show you how to replace dc jacks in a laptop:
This page has the service manual for your laptop:
http://www.scribd.com/doc/13062016/Acer-Extensa-56206419-Service-Manual
Sep 22, 2010 | Computers & Internet
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
Acer 5920g no power
Your DC Power Jack is bad, or the area of the motherboard where the DC power jack attaches to, is bad.
The DC Power Jack, is the small port where your AC adapter,(Charger), plugs into.
This is an example of an average DC Power Jack, for an HP Pavilion laptop, not installed in a laptop yet,
http://www.megaemarket.com/dc-power-jack-hp-pavilion-ze4200-zt117420011721182125.html
If you click on the photo it will enlarge.
The DC Power Jack in the photo is upside down, in relation to how it sits on your laptop's motherboard.
Those flat metal pins shown on top, go down through the motherboard, and are soldered on the other side.
1.Sometimes when the 'charger' plug is in the jack, and is bumped, it can crack the solder joints for the DC Power Jack's flat pins. This makes an intermittent contact. Eventually there is no contact at all.
2.Sometimes it's a bad design of the DC jack, and just from ordinary usage of the user plugging in the charger, and removing it, this can crack the solder joints.
3.Sometimes the small area of the motherboard where the DC power jack is mounted, can crack away from the main body of the motherboard.
To explain:
Crude example;
Envision a laptop's motherboard as having a 1 foot square shape. (It isn't. It's irregular shaped) Now on one side attach a 2 inch square. This 2 inch square, represents the area that the DC power jack is attached to. A 'Peninsula', if you will. There are circuit traces that go along a motherboard. Think of them as Very, flat, thin, strips of copper wire. These 'wires' become stretched, and break as the 'peninsula' cracks away from the main body of the motherboard.
Solution?
Have the DC Power Jack replaced, or the motherboard.
DC Power Jack cost? About $6 to $8 dollars.
Labor? $100 to $150.
The tech has to completely disassemble the laptop, to just the bare motherboard in hand. Then unsolder the DC power jack, resolder a new one in, and reassemble the laptop.
Motherboard cost? About $150 on up. Depends on where you obtain it. (Ebay?)
Labor? $100 to $200.
Jul 12, 2009 | Acer Computers & Internet
Computers & Internet Logo
David Payne
David Payne
