Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Gator gears crunchin
We have an older gator (pre 2000) and the gears crunch when gator is on but stationary - how do we fix
    President:
  • 1,627 Answers
The only way to stop the gears from grinding is to replace the clutch or turn the idle down low enough to get it into gear.The clutch on the engine is the most common problem.
Posted on Apr 26, 2010
Testimonial: "Thanks so much shall try this out."
Having trouble with my softail fxsts harley. when i select any gear it crunches. Clutch seems to be working OK. have adjusted it on cable and at clutch
Hi Virge554, you may need some adjustments in the shifter pawl area with transmission in the bike, for more information about your question please visit the websites below. Good luck and have nice day.Disassembly of Harley Davidson 5 Speed Transmission
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 11, 2012 | 2000 Harley Davidson FXSTS Springer...
Need to rewire a peg perego 12 volt gator
sounds like you have a bad motor, try disconnecting one of the motors and then try it again
Jul 03, 2012 | Peg Perego John Deere Gator HPX
When started from cold my tdi vw bora crunches into 2nd gear and slightly crunches again into 3rd gear after 10 to 15 mins when the car warms up it is totally fine what could cause this?????
try changing the oil, paying great attention to manufacturer's recommendations. Could be oil is way too thick and is sticking things that are supposed to slide, until it warms and thins.
Sep 12, 2009 | 2000 Volkswagen Golf
I have a suzuki rm 125 1994 model when i pull the clutch lever in to put it in gear the clutch doesnt work t jst crunches into gear
Adjust the clutch cable to allow about 1/4" free play at the end of the clutch handle. Don't put the bike in gear until the rpms are near idle speed. The clutch is working fine if the bike does not lurch forward when going into gear at idle speed. Dirty, gritty oil in the gearbox can make the clutch grab. Consider changing oil if grabbing is the problem. The "crunch" you hear is the slider gear engaging into the driven gear. The higher the engine speed when being put into gear the louder the crunch. The slider gear engaging "dogs" can break. Crunching into gear is hard on the gears.
Post a comment to let me know how you come out on this.
Jun 04, 2009 | 2003 Suzuki RM 125
Gear oil level
There is no way to see the level in the gear box. There should be a small plug somewhere on the top the the gear box. You will need a very small funnel to put in. If the gears are crunching or grinding then try putting a little in. Just stanard auto gear oil will do.
May 19, 2009 | 2000 BMW 3 Series
John Deer Gator only drives in low gear.
Sometimes the levers go bad in the shifter, but I would first check the shifter to make sure the switches are engaging. You should also check the wiring on the motors in the rear. Sometimes they come loose and if they are not making a good contact the gator will not go in proper speeds.
You can get great help at http://www.shopjandl.com/mepu0002.html.
They have a toll free number and are very helpfull because the repair them as well.
Mar 28, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
169 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
