Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
When i prime the lawn mower it only runs for a few seconds
  • 4341 Answers
SOURCE: Brand new lawn mower will start but stall after
You have a fuel restriction. Usually you have to disassemble the carb and clean it, but sometimes you can remove the air filter, rev up the motor, somehow, and place hand over intake. this sometimes will **** the restriction through.
Posted on Nov 22, 2010
Testimonial: "ITS NOT FIXED COMPLETE, BUT IT WILL RUN NOW. IT RUNS ROUGH. THANKS FOR YOUR HELP."
SOURCE: mowers is not getting gas
Check your float ... it might be sticking in the upward position when the fuel well fully fills? This would cause the mower to run on the fuel that gets inside the line when you prime it, but since the float stuck in the upward position would close the intake line from the gas tank, your mower would die after the priming fuel is spent.
[The float is located inside the metal bowl beneath the carburator usually, and can be opened by removing a single bolt/screw in the center of the bottom of the bowl. Be careful to pay attention to how the valve-pin attached to the float is attached; usually it's just hooked on very loosely. Thouroughly clean the float, pin & inside of the bowl, then reassemble after making sure the float moves freely.] If the problem isn't solved by this, you might have an obstruction (like a leaf-cutter wasp nest) in your fuel line between the gas tank & carburator? Check the float first.
Posted on Apr 18, 2009
heres2maine
  • 84 Answers
SOURCE: lawn mower does not run.
Needs a new diaphragm. Its between the carb. and gas tank. It collapsed and doesn't allow enough gas to carb. to keep motor running.
Posted on Apr 15, 2010
  • 198 Answers
SOURCE: my lawn mower starts easily, then shuts down. each
disassemble the carb and make sure the float valve is not sticking
Posted on May 10, 2010
rycgl
  • 1545 Answers
SOURCE: My yard machines push lawn
Try removing the brass bolt that holds the float bowl on the carburetor and cleaning ALL the tiny holes in it. Use no metal objects on it as it is also the main jet of the carburetor. Carb/Choke Cleaner aerosol spray works well here. Pay close attention to real small holes near the top in the unthreaded portion of the bolt. Remember, no scraping with metal and no metal wires thru it.
Posted on May 10, 2011
Why wontsmart carb engine start if primed runs for few seconds
dirt or water in the carby jets
priming it just puts a squirt of fuel in the manifold and that is the initial start run
Jun 19, 2015 | Garden
My lawn mower when start not continue running
probably a small amount of water in the carb...which if left for a period of time will clog up one of the small orifices in the carb and prevent fuel flow. will start when primed but quit in a few seconds.
remove the carb and clean with a GOOD cleaner such as "gunk" blow oout with compressed ait and ensure all the jets are clear
Aug 14, 2014 | Garden
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Weed eater starts but only runs for a few seconds and cuts off. prime it and starts but only runs for a few secounds and cuts off again
check gas line in gas tank. See if Stone filter broke off of gas line.
Very common with this new crappy Ethanol gas
Aug 23, 2013 | Garden
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Lawn mower will not start. I changed spark plug, gas is in the mower and oil, mower still does not run
If your mower will start when you prime it, and then it dies right away, you have a carberator pluged. If after primeing the mower and it will not even start for a few seconds, you have lost spark. If you have no spark, this can be cause by two things. First, the magnito could have gone back, but this dosen't happen to often, but it can happen. First, check to see that the cable from the brake handle has not stretched. This controls engine brake and its also the kill switch, which kills the spark. Get acess to your engine brake, and you will find a wire connected to a tab. Remove this wire and try to start the mower. If it starts, replace the control cable. If it dosen't start, hook the wire back up and replace the magnito. I hope this is of some help
May 05, 2010 | Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
395 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
