Question about Bunn 12 Cup Coffee Brewers with 3 Lower Warmers: Automatic Brewers w/3 Lower Warmers - FREE Shi...
Reservoir heats but won't dispense
I have a commercial 3 burner Bunn with automatic water feed. You can hear the water heating in the reservoir but nothing comes through down into the pots. What could the problem be?
  • Bunn Master
  • 2,237 Answers
Make sure the tank is full. it'll take 2 1/2 brews to fill the tank. keep brewing until the water comes out. and yes, clean out the sprayhead holes and the drain in the fill tray in the top.
Posted on Sep 13, 2014
    President:
  • 1,618 Answers
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Posted on Apr 27, 2010
My Bunn O Matic VP17-3 will not brew , the heating elements are working or at least hot but will not dispense the water! what can i do
You should call your vendor for service on any commercial brewer. (Especially if it's on loan from them)
*** the following is for information only as all repairs should be performed by a qualified tech.***
The start switch activates the timer (analog or digital) board which turns on the water feed or brew valve depending on the model.
* Check momentary brew switch.
* Check the on/off switch
* Check the timer. Digital timers tend to be sensitive to electrical storms. Analog timers have a dial and are more tolerant of electrical surges.
* Check the water fill solenoid. Should be a definite click when activated. Water filling sound should be very clear.
* No water flow then check the water supply line if it's on.
* Final; call for service to be safe.
Aloha, ukboy57
Nov 13, 2016 | Bunn Coffee Makers & Espresso Machines
Vp17-3 bunn o matic will not brew no water will come out if i wait about 15-20 mins it will start spitting out some water like 1/4 full! The heating elements are working on all 3 burners
You have 2 water valves on that coffee maker a water inlet and a dispense valve the warmers are only heat plates the element is inside tank Bunn has a great site for manuals it's a free download
Nov 13, 2016 | Electrical Supplies
If Bunn unit has been stored for a while, how do i clean it and get it ready to use?
Hi, W/D here.
To get your Bunn working again, place a filter into the basket, fill the reservoir, and allow it to begin dispensing into the carafe. This will take several pots of water to get it filled and overflowing (dispensing). Plug it in, and let the reservoir heat up. It's not necessary at this point to have the heating plate turned on, but you can do so if desired to check that it is working, then turn it back off. Once you hear the reservoir heating up, pour in 8 ounces of white vinegar, and let the machine dispense into the carafe. Place an additional 8 ounces of white vinegar into the carafe, and pour back into the reservoir. Let the water heat up again, and let the vinegar solution sit in the reservoir for about 30 minutes. Top off the carafe with cool water and allow the carafe to cool with the warming plate turned off. After the 30 minutes, pour the contents of the carafe back into the reservoir, and it will dispense again. The water in the reservoir will heat up again. Check the coffee filter for residue. If you see a lot of grainy material, change the filter, and repeat the cycle until the filter comes out clean. Save your old filters as you go. Lay them out in order on paper towels, and you'll be able to mark your progress. When the filters clear up, discontinue recycling the vinegar solution and, instead, fill the reservoir with fresh water. The sediment has by now been freed up (de-scaled) and will continue to come off in smaller and smaller quantities. Each time you place fresh water in the machine, the dispensed liquid will smell less and less like vinegar. When no vinegar odor can be detected, you are finished.
Best regards, --W/D--
Apr 06, 2011 | Bunn BT10B Coffee Maker
It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
Hope this helps.
Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
We have a commercial 3 burner Bunn automatic coffee maker that only puts out warm water and makes weak coffee
If you're sure that you've followed the operation procedures correctly, the the thermostat of the Micro wave needs to be adjusted by a qualified person/Technician. if the problem persist, then you need to change the Element/Heating coil of the M-wave.
Oct 13, 2010 | Microwave Ovens
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
Water in resovoir boils away. Do I need a thermostat?
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
Dec 02, 2009 | Bunn VPS Coffee Maker
Bunn automatic coffee maker will only make half a pot, this is a commercial unit with 3 burners
try cleaning with white vinegar(50/50 with water)may have calcium deposits supposed to clean once a month-let it soak overnight use coofee filter to catch deposits run numerous times then throughly rinse with water!!! :)
Jul 04, 2009 | Bunn NHB Coffee Maker
Bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
Bunn 12 Cup Coffee Brewers with 3 Lower Warmers: Automatic Brewers w/3 Lower Warmers - FREE Shi... Logo
255 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
